Go to Post If I run into some of your team's student coaches/drivers on the field of battle someday, I still might ask 'em what they're doing after high school. :) - Ken Patton [more]
Unread 13-01-2017, 17:40
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Cutting Rhino Tracks??
Has anyone ever cut Rhino Tracks and reattached to make a shorter belt? If so any recommendations?
Thanks and hope everyone is having a great build season.
Unread 13-01-2017, 17:54
RoboChair's Avatar
AKA: Devin Castellucci
Re: Cutting Rhino Tracks??
1/10 would not recommend. You will lose the strength of the fibers running through it by cutting it. I assume you want it for drive purposes?
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 13-01-2017, 18:00
Bluejacket Robotics
Rookie Year: 2015
yea we were throwing some ideas around for a smaller track drive system using smaller rhino tracks.
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
If you want a different length, order it from brecoflex or something, don't try cutting it to make it shorter.
Unread 13-01-2017, 18:03
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
As someone who used tracks on our robot for many years I can confirm this. The tracks have wire fibers running down them that give them strength, cutting means you loose this.
A much better option would be to find the manufacturer of the tread and order them in a custom length as we did before AM sold them.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 13-01-2017, 18:04
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Academically, why are you using tracks? It doesn't seem like anything in this game would require them, and they introduce additional complexities over using wheels.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 13-01-2017, 18:10
RoboChair's Avatar
The manufacturer will probably quote you around 2-3 weeks lead time on said custom belt. Having worked with them for my work.
Unread 13-01-2017, 20:56
cbale2000's Avatar
AKA: Chris Bale
You're not wrong, the cost goes up substantially too. Back in the day we typically paid around $300 per track and ordered them at the very start of the build season (or ordered a lot of them and just used spares from past years).
We've since opted to go with a number of small wheels to get almost all of the advantages of tracks but without the need to use custom parts. The reliability is also much higher and the turning of the robot is far better since you don't have to deal with as much scrub.
