Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
Unread 11-01-2017, 20:55
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Network Tables: Please explain like I'm 5
Specifically running it outside a robot program on a Win10 laptop and on a raspberry pi.
Assume I don't know anything about Maven repositories, or native paths, or external jars... because I don't.
Unread 11-01-2017, 22:00
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Network Tables: Please explain like I'm 5
I can explain how to use it, if that's what you want.
1. Clone https://github.com/wpilibsuite/ntcore
2.
./gradlew :native:build -PskipArm
3. Find built desktop NetworkTables JAR (<place you cloned>/native/build/libs)
4. Use JARs in project
NetworkTable.setClientMode();
NetworkTable.setNetworkIdentity("Name of my coprocessor or DS or whatever");
NetworkTable.setTeamNumber(5401);
NetworkTable.initialize();
// now get the network table that corresponds to the SmartDashboard class of WPILib
NetworkTable smartDash = NetworkTable.getTable("SmartDashboard");
// now use table to put data
smartDash.putNumber("VisionAngle", 42.0);
For the pi, you'll need to download a pi toolchain
Then,
./gradlew :arm:build -PcompilerPrefix="C:\Path\To\RPi\Toolchain\bin\arm-linux-gnueabihf-"
Find build probably in <place you cloned>/arm/build/libs
Use JARs in code on Pi as above
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 12-01-2017, 03:48
Volunteer, WPILib Contributor
no team (Waiting for 2021)
I am actually working on a gradle build system to automatically set up for running on either a Raspberry Pi or a Windows desktop. You can see the example at https://github.com/wpilibsuite/Visio...ee/master/Java, and can download the zip with the entire setup at http://first.wpi.edu/FRC/roborio/cop...JavaGradle.zip.
The Readme has instructions on how to set everything up. It's built for running camera processing, but it's fairly easy to make it just do networktables, as its already setup to connect to networktables.
Team 4488 - Mentor 2013-2016
Unread 12-01-2017, 08:38
kmckay's Avatar
Rookie Year: 2015
Conveniently, I'm trying to use it for camera processing
Will review, thanks.
Unread 12-01-2017, 11:15
TimO TimO is offline
AKA: Tim Ohling
FRC #4662 (Byte Size)
TimO is an unknown quantity at this point
This looks like something we can use. But:
<click on link>
Forbidden
You don't have permission to access /FRC/roborio/coprocessors/JavaGradle.zip on this server.
TimO
Unread 12-01-2017, 12:54
<click on link>
Forbidden
TimO
Hmm looks like the link is having issues. I pushed a version of it to the GitHub release page, which can be found here https://github.com/wpilibsuite/Visio...ses/tag/v0.0.1. The zip is just a zip of the repo, so you could also just clone the repo.
Unread 12-01-2017, 20:41
kmckay's Avatar
Rookie Year: 2015
With the standard WPIlibraries installed, do I need to do anything to run in eclipse for testing purposes? I am getting an ntcore not found. I have the import statement, the jar's in the build path...
Unread 12-01-2017, 21:46
AKA: Tim Ohling
@Thad
thanks - the gradle setup works for me. Appreciate the effort setting it up.
Unread 12-01-2017, 23:21
I don't know if that project will properly import into Eclipse. Haven't built with eclipse much. Although if you're getting an ntcore not found error, you probably have the wrong version set in the build script. Make sure it's set for windows if you are trying to run it on windows.
Unread 13-01-2017, 05:19
kmckay's Avatar
Rookie Year: 2015
I wasn't specifically using your code there. I went cross-eyed at "Gradle". I will figure that out eventually but not sure that will be during build season. I know there was an online Gradle training recently but build season.
But I did read your code, and try to mimic the NT lines. I had posted a question to the GRIP gutter chat and was told the set server and set team number were unnecessary in the latest versions of nt. Not true?
I'm beating my head against a wall here. I know this is going to be the simplest, stupidest answer, and I'm 90% sure it's in my eclipse build path and not in the code. But every answer seems to require 6 more questions.
Unread 13-01-2017, 09:58
kmckay's Avatar
Rookie Year: 2015
Based on the error I'm getting, its picking up the libraries just fine. Within the libraries, when it executes the System.loadlibrary(ntcore) it can't find the file. It looks like on a windows system its looking for a windows directory. Should there be an ntcore.dll somewhere in my windows directories?
Unread 13-01-2017, 12:12
It should automatically be extracting the library. Which Jar are you using. There is an Arm jar, which is what you would have if you got NetworkTables from eclipse, and the is a Desktop Jar, which has all the native libraries for desktop systems. The Arm jar doesn't include any of the libraries for windows or other systems. You can get the desktop version from here. http://first.wpi.edu/FRC/roborio/mav...kTables/3.1.5/. Just download the version that ends with -desktop.
Unread 13-01-2017, 12:37
If you want to run on a device other then the rio, you want to be using setClientMode() and setTeam(). That will connect to the roboRIO, since the roboRIO is by default the server.
Unread 13-01-2017, 16:42
kmckay's Avatar
Rookie Year: 2015
WORKED!! Thank you! On to the Pi!
And I'm happy to include the server commands, but if that's in the screensteps, I missed it. I asked about it because I stumbled on it in the 2013 screensteps on a google search.
Thank you much. Hopefully I won't be back shortly with Pi problems.
Unread 13-01-2017, 18:12
With pi, instead of downloading that desktop artifact, download the arm-raspbian one. That should be the only thing needed to make it work.
