Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
Unread 13-01-2017, 19:34
WalnutsAndBolts WalnutsAndBolts is offline
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Exclamation FRC 2017 Joystick Control
Hello,
My team is a rookie this year, so we are still trying to figure things out, so sorry about this question if it is a simple answer.
How do I setup the Logitech joystick in Labview? I am looking for the programs and info to do so. Anything helps!
Thanks,
Walnuts and Bolts Robotics Team
Unread 13-01-2017, 19:42
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: FRC 2017 Joystick Control
In the LabVIEW start window, click the tab on the left that says "tutorials." That should get you going pretty quick. You will find that the Joystick subfolder of the WPI VI library has all the VIs you need, and runnable code is already in Begin.vi and Teleop.vi.
