Go to Post I sure hope kickoff comes soon. Otherwise, you're all getting sent for therapy ;) - Rich Kressly [more]
Unread 13-01-2017, 13:17
doot doot
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rapid fuel feeding into shooter
It seems we're all aiming for speed on our shooters, trying to max out balls per second, but I haven't seen a thread yet on how to feed these shooters at a matching rate. Just thought I'd open a discussion, as I think this has the possibility of being the most overlooked component this season. (This is sort of a compliment thread to Realistic high goal scoring rate)
We've seen the blender method used in some robot in 3 days videos, and it does work but it takes too much time to get the balls to the shooter in my opinion.
I'm a fan of the Zou Keeper single file line fed into the shooter, but this presents obvious space usage issues (limiting how many balls you can hold) and human loading issues
Perhaps some combination could work - A blender that lines the balls into a single file chute as you drive across the field so you have a stock of balls ready to go at the boiler, but you could only have so many balls ready to go and you're stuck again with the feed rate of the blender.
TL;DR How is everyone planning to get their fuel from a jumbled mess to the shooter in a timely fashion?
Unread 13-01-2017, 13:21
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Rapid fuel feeding into shooter
You call that a blender? THIS is a blender!
Unread 13-01-2017, 13:30
caleby caleby is offline
FRC #1432
caleby is on a distinguished road
https://www.youtube.com/watch?v=7BndIuKTXsI
Unread 13-01-2017, 14:01
JohnFogarty's Avatar
AKA: @doctorfogarty
Those wheel agitators are nuts hahaaa
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Wow! All those videos look seriously impressive. I do find it interesting that you were able to shoot so many shots in such a short span of time that they knocked each other out of the way as they slowed at the apex of the arc. Do you mind sharing some of the specs on motor, gearing, and wheel?
In regards to other methods of feeding Fuel, an auger similar to those in Icee machines might be an excellent solution. I've seen several people try homemade versions of an Archimedes screw, but I think that the solid shaft and the rather uniform (albeit spiral) travel of the Fuel in the hopper makes for a more difficult integration than the combination of agitation and propulsion the augers offer.
Unread 13-01-2017, 16:05
s_forbes's Avatar
The shooter wheel is a 6" AM wheel, geared down roughly 4:1 from a CIM (It goes way too slow, but that was the quick easy way to build it at the time). The backing material for the shooter is a slightly flexible corrugated composite hi-tech material (cardboard). The recycling can is just a recycling can with a hole in it. Stick some shelf liner on the end of a drill (high speed preferable) and watch the balls fly out!
Unread 13-01-2017, 16:08
Chris is me's Avatar
AKA: Pinecone
What's wrong with the ol' flat polycord elevator we all know and love? Are you specifically looking for "many-to-one" solutions?
The fastest accurate high capacity shooter I can remember is 217's 2009 robot, still one of my all time favorites. Not saying a powered helix is the right call for this game, but it's a hell of a mechanism.
Unread 13-01-2017, 19:46
Registered Muser
Thank you!
I'm not quite sure what you mean by using a polycord elevator for getting Fuel out of a large hopper and into the shooter mechanism. Granted, I wasn't around in 2009 or 2012, so I've only seen polycord as a popular intake component for Stronghold.
Unread 13-01-2017, 19:53
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If you don't rob momentum from the fuel, gravity can feed them at a pretty quick rate.
Unread 13-01-2017, 20:14
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
254 is a good example of this. There were a lot of successful robots in 2009 that had a general design of something like "Wide intake, large hopper, polycord elevator, fast shooter."
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 13-01-2017, 20:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
When it comes to quick feed conveyors, 469 is 2006 is what I think of.
Unread 13-01-2017, 21:03
doot doot
AKA: Brandon Liatys
Yes.
Gravity is pretty great if they're already single file, which is the issue I'm bringing up. Otherwise my guess is it would jam. I guess I should be more specific:
You could do a helix at the cost of volume, and have the balls single file and easily feed into a shooter. Alternatively, if you just have a bucket o' balls, whats the fastest way to get them single file into the shooter?
This has potential
Unread 22-01-2017, 11:29
Billfred's Avatar
Billfred Billfred is offline
5402 is a disciple of the Stephen Kowski School of How To Play Lunacy. No unnecessary choke points (though we will add a little width into the central storage area for extra capacity), sort 'em out early, flow through and get 'em out.
Our game strategy is distilling to "deliver a gear, and get what you're going to get at the boiler quickly". This is probably not the game that is going to win Einstein, but we're rebuilding from missing state last year and we think this will get us back on track. (And look cool as all hell in the process.)
Unread 23-01-2017, 11:40
Tio Tio is offline
Tio is an unknown quantity at this point
what fabric are you using?
Unread 23-01-2017, 13:30
s_forbes's Avatar
If you are asking about the prototype videos that we posted, we are using a sticky shelf lining material from Walmart: https://www.walmart.com/ip/Duck-12-x...Liner/16486841 It has good grip on the balls, but if you use it like we did in those blender prototypes it wears out extremely quickly. Once it wears out it doesn't kick the balls out of the bin nearly as fast.
