Go to Post What if my teams drive train isn't an option? - MARS_James [more]
  #46   Spotlight this post!
Unread 13-01-2017, 14:33
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Realistic high goal scoring rate
Originally Posted by Lil' Lavery View Post
There's flywheel shooter spray and pray where you pump out as many balls as you can past a flywheel shooter at a somewhat sustained rate for a few seconds in somewhat the same area.
Then there's "I shoot my entire hopper at once" spray and pray where you fling 50 balls into the air at once and hope that a large portion of them land in the goal funnel.
*Waits to see the 50 ball catapult*
___________________
- Tennyson, Ulysses
  #47   Spotlight this post!
Unread 13-01-2017, 21:12
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Originally Posted by Kevin Sevcik View Post
Once you work that out, you should wind it up to 8 or 9 per stream, just for the video of the midair traffic jam falling back on your robot.
I suspect what whatever we build will be powered to accommodate this, and I promise a video when it happens. Generally we build this type of mechanism with our target to hit peak power on the motor curves when possible. This means generally we have twice the throughput that the system is designed for. Should be a hoot.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
  #48   Spotlight this post!
Unread 13-01-2017, 21:41
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
The biggest limitation here is not going to be the accuracy or power of your shooter, but the indexing of the fuel leading up to it. Getting the balls from a bulk storage in the robot to a single file line ready to go into the shooter is not trivial and can easily limit your otherwise perfect robot.
  #49   Spotlight this post!
Unread 13-01-2017, 22:10
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
See Simbotics 2009 robot
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #50   Spotlight this post!
Unread 13-01-2017, 22:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Why must they be in a single file line?
  #51   Spotlight this post!
Unread 13-01-2017, 22:14
gorrilla's Avatar
AKA: adam spears
I imagine he was thinking of a single wheel shooter similar to almost all the RI3D teams have been using
Adam Spears
  #52   Spotlight this post!
Unread 13-01-2017, 22:19
AKA: Matt Hagan
Wide wheel shooting is possible but harder to do well. Lots more things to control. It may be easier than indexing single file, but that is what build season is for.
  #53   Spotlight this post!
Unread 13-01-2017, 22:23
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
I wonder if we will see multi stage shooters like the ones used in 2013 return. I could foresee it being more consistent at a high ROF.
2016: FRC 865 Mentor
  #54   Spotlight this post!
Unread 14-01-2017, 03:31
Originally Posted by BoilerMentor View Post
I consulted a very, very intelligent aero friend of mine and called in a favor. His model indicates an optimistic 7 bps directly in front of the goal from a single stream shooter. Coincidentally the tube below the funnel will accommodate 3 fuel with 1/4" between game pieces and between game pieces and the wall. I'm seeing something on the order of 18-21 fuel per second in our future potentially. I will go on record as saying that you need some kind of metering ahead of your shooter and that interface will be EXTREMELY critical if you're aiming for this kind of Lunacy™.
The assumption you are making is that all balls are still lined up at the apex. Break that assumption, and things start to get way more interesting
  #55   Spotlight this post!
Unread 14-01-2017, 08:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
A limited version of this might be a good way to control rof. Small sticky wheel just in front of your shooter spinning at a controlled rate. Conveyor system Infront of the rate control wheel can shove balls together at higher speed and provide a consistent stream for the rate control wheel to pay out.
  #56   Spotlight this post!
Unread 16-01-2017, 11:43
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Originally Posted by Andrew Schreiber View Post
That's the first time I've ever heard him referred to as "intelligent"
  #57   Spotlight this post!
Unread 16-01-2017, 13:25
Cog Cog is offline
FRC #3324 (The MetroBots)
Cog will become famous soon enoughCog will become famous soon enough
Do you know what this model is exactly? I'd like to show it to my team.
  #58   Spotlight this post!
Unread 16-01-2017, 13:57
Chris is me's Avatar
AKA: Pinecone
Why is it harder to do well? Other than spinup time / speed loss (which is a throughput problem not a width problem), I don't necessarily think this is true at all, and it is certainly easier to get a large ball throughput this way.
  #59   Spotlight this post!
Unread 16-01-2017, 14:09
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
My big thing is fitting everything together in a way that emphasizes the priorities in use of space. My old team, FRC 2970, came up with a good design in 2009 for ball throughput from a static hopper. Check us out on TBA for details. My biggest concern isn't so much dump/shooter design, but space and positioning everything else, which is a necessary detail that I feel most teams will need to acknowledge. Considering we can minimize the climb mechanism to around 4 or 5 inches tall at the top of the robot, and we've got around 9 inches on the bottom for drivetrain and intake, and one side has a gear delivery mechanism, how do we optimize the space so that:
- Intake of balls into the on-robot hopper/container is easy
- Output isn't limited by necessary frame space
- We have the power and space for actuators
- We don't lose our balls
- Dumping is consistent and fast
Our priority is not to emphasize use of the top target, so we can use a dumper rather than a powered shooter or turret, but we want to be able to deliver fuel effectively as a backup plan.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
  #60   Spotlight this post!
Unread 17-01-2017, 10:07
FRC #1747
Absolutely. This is where the discussion of spin and the possible benefit/cost of trying to exploit the magnus effect began. Looks like we're going to provide an adjustable mechanical bias to test that hypothesis as well, primarily comparing performance in cases where either no spin or forward spin are imparted on the game piece.
