Failure of FUEL game piece
Today while testing our 2017 robot with competition spec bumpers around our wooden practice field we had a failure of a few balls.
This occurred when the balls were squashed between the fabric covered noodle of the bumper and a wooden field perimeter while driving at a low speed. ![]() The balls are broken, with cracks occurring between many holes. The failures are not along the welded seam but spread from the edge of the holes, or crack the bridge between holes. That occurred after a limited impact with the balls. A similar occurrence to the same ball a second time would most likely cause the ball to be in several separate pieces. It seems like the cracks would be quite difficult to notice when field reset is dealing with 600 balls at the end of the match unless they are physically picking up each ball, and squeezing it to check. Is this an issue others teams have had occur in testing? Last edited by pilleya : 14-01-2017 at 02:42. |
Re: Failure of FUEL game piece
Wiffle balls (or fuel) can take a lot of pushing around but once pressure is applied to them they tend to crack kinda easily. One thing is that the balls you purchased aren't (I'm assuming anyway) official FIRST game pieces, so there's a possibility the actual fuel pieces aren't as frail? There are a lot of knockoffs that break easily.
But don't feel bad about it! Like I said, Wiffle balls tend to crack if pressurized enough so I think everyone, even refs and rest crews are expecting to see a lot of cracked pieces throughout the day and probably won't point any fingers about it. Last edited by NinjaMunkeeNao : 14-01-2017 at 03:01. |
I think that the conditions which caused the breakage( ball against wall) are going to be very common with robots crushing balls when placing gears, shooting, intaking and feeding from hoppers/chutes. Last edited by pilleya : 14-01-2017 at 03:11. |
We actually noticed the same thing. We were testing a shooting prototype, but the balls wern't really compressed that much... yet I noticed that a few of them, not many, but a few, had developed small cracks like this.
A) I'm pretty sure that they are identical to the real ones.
B) Like in previous years, imperfect GAME PIECES are to be expected during regulation play. They get damaged over time and FIRST expects teams to be able to handle the damaged ones. Such as in 2016 with the boulders having small chunks missing or being not quite round or in 2011 (throwback, I know ) when the tubes would not be fully inflated causing many intakes and grabbers not to function properly. TL;DR The damage to GAME PIECES in real competition is to be expected. |
#7
Hi Im jaleel from team 4592 and I have a quick question about compression on the wiffle ball, do you know what compression is best to shoot and pick up the wife ball.
#8
Some plastics (like polyethylene) are more flexible than others (like polystyrene). And most plastics are far more flexible when they're warm than when they're cold. |
#9
I saw you asked this in another thread too. While some teams will give away that information, most teams prefer not to just give away the results of days of prototyping and testing. I suggest if your team hasn't started prototyping shooters (if you plan on building one), you should start very soon testing different wheel sizes, types, configurations, and compression levels to see which works best for you. Good luck!
#10
Huh, we tested the fuel alot, and they handle abuse really well. I actually jumped on one and it bent out of shape then slowly reformed, and i am around 200lbs
#11
We noticed the same thing (cracks) on one of our fuel when we were testing a shooter prototype.
#12
As Ether noted the flexibility of some plastics can vary greatly depending on temperature. Personally I squashed a ball by stepping on it and thought it would certainly be damaged but I watched it pop out on its own. Granted I did realize that I was stepping on something and didn't put my full weight on it. That took place in a warehouse with the thermostat sat at 60 degrees and the balls had been in their long enough that they should been close to room temp.
Since we have several reports of cracking, yet others report that they have survived serious deformation, I have to wonder what the temp was in the location where they were being testing and stored in each case. |
#13
We have one cracked ball so far - it may have arrived with the crack.
#14
It's been around 100 F in Sydney lately, but our build/practice space is air conditioned to probably about 70-75 F. So the balls being cold is most likely not the main issue.
#15
