Go to Post I do know that I cringe every time someone brings up "lawyerism" or some other such nonsense as the reason their interpretation of the rules is right. - Kris Verdeyen [more]
Unread 14-01-2017, 02:30
pilleya's Avatar
pilleya pilleya is offline
Head Cheesecake Chef
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Failure of FUEL game piece
Today while testing our 2017 robot with competition spec bumpers around our wooden practice field we had a failure of a few balls.
This occurred when the balls were squashed between the fabric covered noodle of the bumper and a wooden field perimeter while driving at a low speed.
The balls are broken, with cracks occurring between many holes. The failures are not along the welded seam but spread from the edge of the holes, or crack the bridge between holes. That occurred after a limited impact with the balls. A similar occurrence to the same ball a second time would most likely cause the ball to be in several separate pieces.
It seems like the cracks would be quite difficult to notice when field reset is dealing with 600 balls at the end of the match unless they are physically picking up each ball, and squeezing it to check.
Is this an issue others teams have had occur in testing?
Unread 14-01-2017, 02:52
NinjaMunkeeNao's Avatar
NinjaMunkeeNao NinjaMunkeeNao is offline
i'll literally do whatever :D
AKA: Naomi Christina Alexander
FRC #2395 (The Ninja Munkees)
Rookie Year: 2016
NinjaMunkeeNao is an unknown quantity at this point
Re: Failure of FUEL game piece
Wiffle balls (or fuel) can take a lot of pushing around but once pressure is applied to them they tend to crack kinda easily. One thing is that the balls you purchased aren't (I'm assuming anyway) official FIRST game pieces, so there's a possibility the actual fuel pieces aren't as frail? There are a lot of knockoffs that break easily.
But don't feel bad about it! Like I said, Wiffle balls tend to crack if pressurized enough so I think everyone, even refs and rest crews are expecting to see a lot of cracked pieces throughout the day and probably won't point any fingers about it.
FIRST is amazing because the nerdier you are, the cooler you are!
Wait we're nerds who cares how cool we are lol nvm
Unread 14-01-2017, 03:02
pilleya's Avatar
All game pieces we possess are those distributed in the KOP.
Although we will do everything we can to avoid damaging gamepieces, we are more concerned with the broken fuel particles impacting our own game play and that of other teams. A ball which is effectively in two pieces tends to not go through a intake and shooting mechanism very effectively.
I think that the conditions which caused the breakage( ball against wall) are going to be very common with robots crushing balls when placing gears, shooting, intaking and feeding from hoppers/chutes.
Unread 14-01-2017, 03:45
ShIfTiNgBoT's Avatar
ShIfTiNgBoT ShIfTiNgBoT is offline
AKA: David
FRC #0649
ShIfTiNgBoT is on a distinguished road
That's very odd. From our testing, after some relatively light use, they become VERY flexible. Like you can cave in half of it and pop it back out.
Unread 14-01-2017, 06:41
Green Potato Green Potato is offline
AKA: Tory Farmer
FRC #0422 (Mech Tech Dragons)
Team Role: Tactician
Green Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of light
We actually noticed the same thing. We were testing a shooting prototype, but the balls wern't really compressed that much... yet I noticed that a few of them, not many, but a few, had developed small cracks like this.
Everything that can go wrong WILL go wrong, except the things we expect to go wrong and actually plan for.
Unread 14-01-2017, 08:39
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
arichman1257 will become famous soon enougharichman1257 will become famous soon enough
A) I'm pretty sure that they are identical to the real ones.
B) Like in previous years, imperfect GAME PIECES are to be expected during regulation play. They get damaged over time and FIRST expects teams to be able to handle the damaged ones. Such as in 2016 with the boulders having small chunks missing or being not quite round or in 2011 (throwback, I know ) when the tubes would not be fully inflated causing many intakes and grabbers not to function properly.
TL;DR The damage to GAME PIECES in real competition is to be expected.
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
Unread 14-01-2017, 10:01
Jaleelmoore34 Jaleelmoore34 is offline
FRC #4592
Jaleelmoore34 is an unknown quantity at this point
Hi Im jaleel from team 4592 and I have a quick question about compression on the wiffle ball, do you know what compression is best to shoot and pick up the wife ball.
Unread 14-01-2017, 10:39
Some plastics (like polyethylene) are more flexible than others (like polystyrene).
And most plastics are far more flexible when they're warm than when they're cold.
Unread 14-01-2017, 19:16
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I saw you asked this in another thread too. While some teams will give away that information, most teams prefer not to just give away the results of days of prototyping and testing. I suggest if your team hasn't started prototyping shooters (if you plan on building one), you should start very soon testing different wheel sizes, types, configurations, and compression levels to see which works best for you. Good luck!
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 14-01-2017, 21:18
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Huh, we tested the fuel alot, and they handle abuse really well. I actually jumped on one and it bent out of shape then slowly reformed, and i am around 200lbs
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 14-01-2017, 21:28
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
We noticed the same thing (cracks) on one of our fuel when we were testing a shooter prototype.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 14-01-2017, 21:46
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
As Ether noted the flexibility of some plastics can vary greatly depending on temperature. Personally I squashed a ball by stepping on it and thought it would certainly be damaged but I watched it pop out on its own. Granted I did realize that I was stepping on something and didn't put my full weight on it. That took place in a warehouse with the thermostat sat at 60 degrees and the balls had been in their long enough that they should been close to room temp.
Since we have several reports of cracking, yet others report that they have survived serious deformation, I have to wonder what the temp was in the location where they were being testing and stored in each case.
Unread 14-01-2017, 21:57
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We have one cracked ball so far - it may have arrived with the crack.
Unread 14-01-2017, 22:02
pilleya's Avatar
It's been around 100 F in Sydney lately, but our build/practice space is air conditioned to probably about 70-75 F. So the balls being cold is most likely not the main issue.
Unread 14-01-2017, 22:03
MARS_James's Avatar
Always Scouting
AKA: James Comstock
So we have jumped on them at a range of about 47 to 83 degrees idk if anyone is doing it in temperatures outside this range
