Go to Post We design for being on a dysfunctional alliance: all the time. - boomergeek [more]
Unread 14-01-2017, 10:39
frodobaggins05's Avatar
frodobaggins05 frodobaggins05 is offline
AKA: Wiring Specialist
FRC #2783
Team Role: Electrical
Rookie Year: 2016
frodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these parts
Re: Using CIMCoders with Talon SRXs
Originally Posted by dardeshna View Post
When wiring CIMCoders to talons using breakout boards we've been getting inconsistent readings. Moving the drivetrain one direction makes the encoder values increase significantly more than moving it the same distance in the other direction (factor of 4 to 10). We don't have this issue when plugging into the RoboRio directly. A spare grayhill we had also worked fine.
We tried adding 10K ohm pull up resistors which seemed to work for a little while before we began to get inconsistent values again.
Has anyone else had this issue before and are pull up resistors the proper solution?
Are your readings only inconsistent while running the robot?
