Go to Post You and I have never met, but I am certain that if we went to the same school, we would have been good friends. - Molten [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 13-01-2017, 12:59
Dave Hurt Dave Hurt is offline
Mostly Harmless
FRC #6413 (Degrees of Freedom)
Dave Hurt is on a distinguished road
No robot code, but can start it manually
I've setup robotpy 2017.0.2 on my rio and pushed a very simple project to it. Deploy goes ok, but the dashboard says no robot code. So I ssh'd into the rio and started the code manually and then everything started working. Dug around a little bit and I can't find a cause for it, anyone have any thoughts? Thanks!
Unread 13-01-2017, 15:48
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
Re: No robot code, but can start it manually
I just took some code and pushed it to the roborio via usb, worked fine. Driver's station reports it perfectly. Don't know what to say bud.
Unread 13-01-2017, 16:28
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
The best way to check this would be to try using the --nc flag to the deploy command to see if there's any error messages that show up. You can also look at the console in the driver station to see if messages show up there (it'll show the same thing).
Unread 14-01-2017, 14:29
applesauce2011 applesauce2011 is offline
Rookie Year: 2016
applesauce2011 is an unknown quantity at this point
I'm working with Dave, these are the messages we see in in the Driver Station
env: can't execute '/usr/local/frc/bin/netconsole-host': No such file or directory
Warning 44002 Ping Results: link-bad, DS radio(.4)-bad, robot radio(.1)-bad, cRIO(.2)-bad, FMS-bad FRC: Driver Station ping status has changed. Driver Station
Unread 14-01-2017, 14:40
virtuald's Avatar
RobotPy Guy
Did you install using the manual instructions, or by using the installer?
In the RobotPy installation package, there's a directory called 'opkg_cache', and it should have two packages... Python and netconsole-host. If you don't install netconsole-host, you'll get that error. If you use the 'install-robotpy' installer command, it should already do that for you.
Feel free to get on the RobotPy gitter channel and I can assist in realtime.
Unread 14-01-2017, 15:05
virtuald's Avatar
RobotPy Guy
To follow up with others, they were installing last year's release of RobotPy, which is why netconsole-host wasn't being installed.
