Go to Post Well, it worked in inventor . . . - Chris Fultz [more]
Unread 10-01-2017, 17:48
DevOrc's Avatar
DevOrc DevOrc is offline
FRC #4283 (INSPIRE ROBOTICS)
Rookie Year: 2016
DevOrc is an unknown quantity at this point
Serial Port Not Finding Pixy Camera
We are trying to use the Pixy camera for vision targeting. We have it hooked up to the USB Port on the RoboRio. However we keep on getting the same error when we create the Serial Port object.
 java.lang.RuntimeException:  Code: -1123. HAL: The specified serial port device was not found
 	at edu.wpi.first.wpilibj.hal.SerialPortJNI.serialInitializePort(Native Method)
 	at edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:112)
 	at edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:160)
 	at org.usfirst.frc.team4283.robot.vision.RobotCamera.initTeleop(RobotCamera.java:21)
 	at org.usfirst.frc.team4283.robot.Robot.teleopInit(Robot.java:68)
 	at edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:123)
 	at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)
Unread 10-01-2017, 17:57
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Serial Port Not Finding Pixy Camera
If you log into the web dash on the roboRIO, http://wpilib.screenstepslive.com/s/...o-webdashboard, you should see 3 serial port objects. What shows up for the last one? ASRL1 and ASRL2 are the built in serial ports.
Team 4488 - Mentor 2013-2016
Unread 10-01-2017, 18:08
DevOrc's Avatar
Rookie Year: 2016
The web dashboard shows three other things on the list:
1. CAN Interface
2.Pixy
3.Pixy
Unread 10-01-2017, 18:21
1. CAN Interface
2.Pixy
3.Pixy
So they show up, but I need the actual names of the serial ports. If you click on each one, what data does it show? I don't remember the exact name, but there should be a string that starts with /dev . can I get that name?
Unread 10-01-2017, 21:28
So doing some research, and the Pixy is not a USB serial device. It's USB connection uses a custom app to talk to the device. So that is why it is not working. However, you should be able to hook up the uart on the expansion connector to the roborio uart on the MXP, then use the MXP setting for the wpilib serial port. Note do not try to hook up to the RS-232 port on the roboRIO, as this will break the Pixy.
Unread 11-01-2017, 06:44
DevOrc's Avatar
Rookie Year: 2016
Ok! I will try that later when we have our meeting. Thank you!
Unread 11-01-2017, 15:06
DevOrc's Avatar
Rookie Year: 2016
Ok, I talked to the team today and We have two questions:
1: What cable would we use to hook it up to the MXP Port?
2: Could we use the NVIDIA Jetson?
Unread 13-01-2017, 08:56
Xanawatt Xanawatt is offline
FRC #1024
Xanawatt is an unknown quantity at this point
You would most likely have to make a custom cable(ours is just several single pin connectors all hot glued in the connection). We used the I2C interface and it works ok. And if you use the I2C, you dont even have to connect it to the mxp, you could just connect it directly to the RoboRIO. I would love to share the code and help
Unread 14-01-2017, 14:59
Coach Seb's Avatar
Coach Seb Coach Seb is online now
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Please share !!! i will be the next one asking as soon as my dev environemnt is setup....
Unread 15-01-2017, 21:50
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is on a distinguished road
I'm guessing this might be code Xanawatt is referring to?
https://github.com/Xanawatt/PixyI2C
Just a guess..
I'd like to see more info how you or anyone else actually connected the pixy to the hw. Wiring info and/or pics of what you did would be really helpful. We are trying to figure out which method to use to connect pixy to roborio. I think our choices are(in order of preference) i2c, uart serial, or plain ol analog/digital.
Related, i also found a few repos that contained what looks like uart serial code. This is just one example: https://github.com/Zero2848/PixyCamTest
