Go to Post I've heard of mentors who keep talking until they are blue in the face, but this is my first time actually seeing one. - Richard Wallace [more]
Unread 14-01-2017, 16:41
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: New RoboRio image missing code
Have you installed java on the roboRIO after updating it to the 2017 image? I do not know when the netconsole-host program would be sent to the roboRIO, I assume it would be included in the 2017 image or part of the roboRIO java install assuming that it is only used in java deployment.
Also have you confirmed your code is working? Last year I recall helping a team that just removed their PCM but did not remove the code. They had similar symptoms, the code was running but stuck in an initialization loop so the Drivers Station reported no robot code was running.
