Go to Post FIRST is an amazing combination of principles that, when applied to the world, has had a monstrous effect on the way High School students learn, think, and relate to others. - Amanda M [more]
Unread 14-01-2017, 16:19
XxTerribleLiexX XxTerribleLiexX is offline
FRC #6722
XxTerribleLiexX is an unknown quantity at this point
Question Loud noise in Rookie Chassis
Hello, we are the rookie team 6722 Seahawk Metal. So are about to cut our drivetrain to be in the correct volume until we came across a noise in our chassis. So we took apart the Andymark's Toughbox Mini and we keep hearing this strange noise between the two toughboxes. Below I've put a link to the two of the sounds. Are those sounds suppose to sound like that?
One Drive:
Side One
https://1drv.ms/v/s!ApTGSNT-kKAgiBrseFSAFCjtR6p3
One Drive:
Side Two
https://1drv.ms/v/s!ApTGSNT-kKAgiBuidwRtTG2MmCL4
Thank You!
Unread 14-01-2017, 16:24
cscottm cscottm is offline
Crazy Person
FRC #2502 (Talon Robotics)
Rookie Year: 2015
cscottm will become famous soon enoughcscottm will become famous soon enough
Re: Loud noise in Rookie Chassis
Toughbox minis are supposed to be ran whilst lubricated for a period of time, andymark recommends 30 min.
You also should have a lot more lubrication on those gears. (they give you lots of the tacky grease, use it.
Thirdly, I would recommend running the motors unloaded, with grease for the extended period of time to properly "Wear in" the gears. (I don't know the correct word here)
Unread 14-01-2017, 16:27
FRC #6722
Thank you so much
Unread 14-01-2017, 16:28
FRC #6722
We will definitely try it!
Unread 14-01-2017, 16:53
Why_A_Username?'s Avatar
Why_A_Username? Why_A_Username? is offline
AKA: Jacob Pilch-Bisson
FRC #2910 (Jack-In-The-Bot)
Team Role: CAD
Rookie Year: 2015
Why_A_Username? has a spectacular aura aboutWhy_A_Username? has a spectacular aura about
You are actually supposed to run the gearboxes WITHOUT grease for 30 minutes each before greasing them to properly "burn in" the gearboxes. It is generally ok if you do not do this, but keep it in mind for future gearboxes. The reason you ru without grease is so the shavings of the gears running together from that first run do not mix with the grease. It won't cause any significant disadvantage if you don't, but it will lead to less total reuse of the gearboxes.
It will be very loud if you burn in the gearboxes correctly for that first run, but after greasing they will sound a lot smoother.
Hope this helps.
"I don't remember how to make that! It came to me in a dream, and I forgot it in another!" -Professor Hubert Farnsworth
"The only difference between science fiction and science is time"
-Dean Kamen
Unread 15-01-2017, 07:23
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Run in and grease will help for sure. Once you install the rest of the gear box, so each shaft is supported on both sides, and they are fully enclosed they will sound different too.
Unread 15-01-2017, 07:57
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
We should, but never do, wear in the gears without grease, but we do always use ALL of the packet that is provided. It looks really excessive at first, but keep in mind that a lot of that grease will get flung off the gears and wind up stuck to the inside of the box.
I didn't break it... this time.
