Go to Post An extra week of driving practice and shakedown outweighs a lot of ooo-shiny. - Billfred [more]
Unread 14-01-2017, 11:31
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
How do we curve an aluminum shooter panel?
We've got a shooter nearly finished and ready to put onto the robot. We can make a plexi curved panel to expedite balls to the shooting mechanism using a heat gun and person power. We don't have any fabrication abilities on site. How should I teach my team to do this with thin aluminum? I didn't want to purchase a high dollar English roller as I'm trying to keep our team "on budget" for a change. haha. Any pearls of wisdom would help. Also if anyone has a reasonablly priced fabricator source in the Arlington, Texas area, please drop me a PM on Chief Delphi. We're ahead of schedule. I don't want this part of the robot to be an obsess point for the team. I'm just a teacher....not an engineer or shop instructor. My practical knowledge is no help to the team.
Thanks in advance!
Steve Miller
FRC 3355
FTC 10756
Purple Vipers
Unread 14-01-2017, 11:40
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Re: How do we curve an aluminum shooter panel?
sure you can use polycarbonate and bend it. It takes some time and patience. You can compensate imperfection (uneven bending or gents) by Velcro (soft side). Bending 1/8" aluminum sheet is difficult, but if you can get thinner, shape them and laminate. In either case having back support to keep the curvature would help.
Edit: Just make sure that curve does not change after few matches. Supporting in the convex dice will help. In pause we have used wood, which was easier for is to cut ca use it as support.
Unread 14-01-2017, 14:05
ClayTownR ClayTownR is offline
FRC #0100
ClayTownR is a jewel in the roughClayTownR is a jewel in the roughClayTownR is a jewel in the roughClayTownR is a jewel in the rough
I would use perforated aluminum sheet. We've used it on our prototypes and it's tough, light, and easy to bend.
Gesendet von iPhone mit Tapatalk
Unread 14-01-2017, 17:12
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Clamp your aluminum to a work bench with 1x1 or other straight piece and bend a little, move and bend a little and so on and so on.
It will take a while but if you are careful you can get a pretty nice curve.
Unread 14-01-2017, 17:59
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
You could make a wood form and bend the metal around it. Due to bounce back you will have to bend it to the final curve off of the form but it is still a useful way to make sure your curve is correct.
2016: FRC 865 Mentor
Unread 14-01-2017, 22:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've used a couple of "rails" for curved shooter backs....it doesn't really need a wide, single panel, does it?
I like to choose materials based partly on what facilities we have to work with said materials. If we don't have a machine that will do what we want to do with that material, I find a different material that we can deal with.
Unread 15-01-2017, 11:50
DonRotolo's Avatar
Back to humble
FRC #0832
What they ^^ said.
However:
1. Never use Plexiglass (Acrylic) on a robot; It shatters and breaks, dangerously.
2. Polycarbonate (Lexan, Makrolon) bends like aluminum, no heat needed. For a gentle curve, use thin (1/8" or so) and it will bend just fine to a smooth curve: Just secure it along its length so it stays bent.
3. Aluminum is great, but visibility is restricted.
4. Much like Polycarbonate, aluminum does not need to be permanently bent, simply secured in position because it is somewhat flexible.
Unread 15-01-2017, 16:15
dkavanagh dkavanagh is offline
FRC #0578 (Red Raider Robotics)
Rookie Year: 2015
dkavanagh is an unknown quantity at this point
We've prototyped with a 3/4 plywood arc that we cut on our CNC router, but you could possibly do same with a saber saw and some sand paper. That plus double wheels seems to work well.
Unread 15-01-2017, 17:15
Jsteel Jsteel is offline
Jsteel is an unknown quantity at this point
We did our cam grabber during Recycle Rush by making a wood form and then forming the aluminum to it. We cut a 4 by 6 into the curve we wanted, then put the aluminum in the middle of the two cut pieces and clamped them shut.
The watchout - the aluminum will spring back somewhat - we ended up doing it twice, the second time with a smaller diameter curve cut on the wood than we intended the final aluminum curve to be.
It worked adequately.
Sent from my iPhone using Tapatalk Pro
