Go to Post I don't think we should only be pointing at those with exceptional bots, but those that we consider a role model team in all aspects, not just in technical design - tribotec_ca88 [more]
Unread 14-01-2017, 18:03
randy_pham randy_pham is offline
FRC #0498 (Cobra Commanders)
Rookie Year: 2016
randy_pham is an unknown quantity at this point
Maxbotics Ultrasonic Sensor Not Working
We are trying to use the Maxbotics Ultrasonic sensor as an analog input. However, we are not getting responsive voltages from the sensor.
package org.usfirst.frc.team498.robot;
import edu.wpi.first.wpilibj.AnalogInput;
public class AnalogUltrasonicSensor2017 {
	AnalogInput AI;
	public AnalogUltrasonicSensor2017(Ports ports) {
		AI = new AnalogInput(ports.ULTRASONIC_SENSOR); // !!!MUY IMPORTANTE!!!
	public double GetRangeMM() {
		double output = 0;
		output = AI.getVoltage();
		output = output / 1000; //Measured in millivolts
		output = output / 0.977;
		return output;
	public double GetRangeInches() {
		double output = GetRangeMM();
		output = output * 25.4;
		return output;
	public double GetVoltage() {
		return AI.getVoltage();
Unread 14-01-2017, 18:32
Re: Maxbotics Ultrasonic Sensor Not Working
Double check your conversion factors.
Unread 14-01-2017, 19:35
Rookie Year: 2016
We are getting unresponsive voltages. AnalogInput.getVoltage() just returns a value that hovers between 0.2 and 0.3.
The conversion factors may be off, but that isn't the problem we're trying to fix.
