Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 08-01-2017, 13:23
ChoccyMelk's Avatar
ChoccyMelk ChoccyMelk is offline
FRC #3617
ChoccyMelk is an unknown quantity at this point
Question FRC Radio Configuration 2017
We were able to load the new firmware to this years radio, and get it to configure correctly. The network would not appear however, and the wireless light never comes on. We also attempted to connect in wired bridge mode to no avail. Any ideas as to how to make it work?
Unread 08-01-2017, 14:22
Jotu Jotu is offline
FRC #1918
Jotu is an unknown quantity at this point
Re: FRC Radio Configuration 2017
We had issues with this as well. What worked for us was putting something in the (optional) Robot Name blank.
Unread 12-01-2017, 18:46
ChoccyMelk's Avatar
FRC #3617
That worked for us too. Thanks!
Unread 13-01-2017, 08:11
FRC #1918
There's also an updated version of the Radio Configuration tool has been released that fixes this: https://usfirst.collab.net/sf/frs/do/viewRelease/projects.wpilib/frs.frc_radio_configuration_utility.frc_radio_conf iguration_utilit_2
Unread 13-01-2017, 19:52
Repasky379's Avatar
Repasky379 Repasky379 is offline
AKA: Matt
FRC #0379
Repasky379 is an unknown quantity at this point
We're getting a similar problem. We updated firmware and configured the radio, but connecting to upload code or connect to the dashboard doesn't work. We can connect to the network through the laptop but we can't actually interact with the robot. Seems like the radio isn't communicating with the RIO.
Unread 14-01-2017, 19:33
maupalo maupalo is offline
FRC #5312
maupalo is an unknown quantity at this point
Hi, I'm having trouble loading the firmware to the radio. I'm following the instructions of this manual: http://files.andymark.com/OM5P-AN_QuickAP_Setup.pdf
It doesn't connect when it displays "Listening on interface"
Any suggestions?
Unread 14-01-2017, 20:36
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Did you follow R63?
Unread 14-01-2017, 22:46
Any suggestions?
Don't use those directions.
Use the FRC Radio Configuration Tool found at: https://usfirst.collab.net/sf/frs/do...ration_utility
And follow the directions at: Programming your radio for home use
Unread 03-02-2017, 09:30
chavezc733 chavezc733 is offline
FRC #6183
chavezc733 is an unknown quantity at this point
Cool Re: FRC Radio Configuration 2017
We just recently had the same problem. What we did was download the radio configuration utility on to a another computer (We used a desktop) and it worked like a charm.
You could try doing that and hopefully it helps. I'm thinking it might be a windows10 driver issue because the laptop we were using was windows10 and that would not work. When it connected it to the desktop (running windows 7) it worked on the first try.
I contacted John Novak about the problem and his reply is as follows, "it happened to several at our workshop last week. my assessment right now is to try different computers. USB to Ethernet adapters failed and laptops need the WIFI totally disabled at the adapter level. even when I got it to work it took multiple tries. A desktop may be more likely to work"
Unread 03-02-2017, 09:58
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We have also had issues running the configuration utility on laptops that have multiple ethernet adapters. We got it working by installing the configuration tool on a classmate drivers station.
(it seems the more ethernet choices the less % of being successful)
The sooner we get behind schedule, the more time we have to catch up.
