Go to Post -Our engineering mentor, Mr. Wittel- *crossing arms and sitting down* "Ahhh. I love work. I could watch it all day." - OverdriveAdge [more]
Unread 11-01-2017, 19:30
MikePerreman's Avatar
MikePerreman MikePerreman is offline
FRC #0247
MikePerreman is an unknown quantity at this point
Exclamation Well, this is getting a bit old, but here is round 3
so, brand new laptop, i installed the update suite, cpp and java plugins, well, surprise surprise, the mdns doesn't work right, i can connect fine over usb and ethernet, if i set the roborio to a static 10.2.47.2, just put that in the ds, and dumping code seems to work ok. but i feel it more of a workaround, not a fix. i am running windows 10, and it would appear that, between windows and dell, its up to date. is there a mdns that im supposed to install as a worst case senerio, or what. this is the 3rd (unique) laptop that has this problem. what have i done wrong?
nevermind, dumping code doesnt work, it gets here:
get-target-ip:
[echo] Trying Target: roboRIO-247-FRC.local
Unknown host: roboRIO-247-FRC.local
[echo] roboRIO not found via mDNS, falling back to DNS
Unknown host: roboRIO-247-FRC.lan
[echo] roboRIO not found via DNS, falling back to static USB
[echo] roboRIO found via static USB
dependencies:
then stalls out, the bot is not connected via USB, only wireless
Programmer - A creature known for converting Caffeine into Code.
Unread 12-01-2017, 00:19
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Well, this is getting a bit old, but here is round 3
Using static IP addresses is perfectly fine and plenty of teams use them. If you want to continue troubleshooting the networking over mDNS, please make sure you have done the following:
Is your laptop able to obtain an IP address from the radio?
Unread 12-01-2017, 16:17
FRC #0247
ok, everything has been updated, i am getting the ip 10.2.47.107, and everything has been restarted. still no mdns. (going to the ds and scanning tells me none found, however putting in 10.2.47.2 connects to the bot)
Unread 13-01-2017, 21:32
FRC #0247
i dont approve of bumps, but this is urgent
Unread 14-01-2017, 11:16
frodobaggins05's Avatar
frodobaggins05 frodobaggins05 is offline
AKA: Wiring Specialist
FRC #2783
Team Role: Electrical
Rookie Year: 2016
frodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these parts
Do you have a roborio on your robot?
Unread 14-01-2017, 11:17
FRC #2783
Rookie Year: 2016
If so, have you installed labview on your computer?
Unread 14-01-2017, 12:45
FRC #0247
yes, we have the roborio on our bot, and i have not installed labveiw, we are a java team, so i havent even bothered with that. heres some more info on my situation:
So, our programming mentor and i cannot connect to the RIO over wireless, tethered works just fine, and infact, when tethered, one the tethered is disconnected, we keep wireless comms until you disconnect from the radio, and reconnect. in the DS the 'light' next to robot radio is on. pinging roborio-247-frc.local, on my laptop results in something to the extent of host name not found, and on the mentor's we get a destination host unreachable. however, on the other programming laptop, works first try, every try. ive disabled IPv6 and both mDNS and ni mDNS is allowed through the firewall of my laptop, if a model helps, its a dell inspiron 15.
here is the versions from the DS
DS: 17.0a11
RIO: FRC_roboRIO_2017_v8
Lib: Java 2017.1.1
PCM: 1.65
PDP: 1.40
Unread 14-01-2017, 12:47
FRC #0247
is there a different board that this thread should be on?
Unread 14-01-2017, 13:01
FRC #2783
Rookie Year: 2016
Try installing labview and using that.Roborio and Labview are both made by National Instruments and are made for each other
Unread 14-01-2017, 13:31
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
You definitely shouldn't need to install LabView (source: our team doesn't have this issue and doesn't have LabView installed).
Try the following fixes. Any one of them might solve your issue.
Have you tried reflashing the radio firmware (see ScreenSteps for instructions)?
Have you tried a different radio?
Have you tried a different roboRIO?
Have you tried reflashing the roboRIO firmware?
Sent from my iPhone using Tapatalk
Unread 14-01-2017, 13:39
FRC #2783
Rookie Year: 2016
You dont need to use Labview but they work better together and can eliminate a lot of problems
Unread 14-01-2017, 14:55
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Shot in the dark here... Have you checked whether Windows Firewall is disabled? That is strongly recommended. If you absolutely can't/won't disabled it, you can allow the NI mDNS Responder application through the firewall.
No. Just no. The RoboRio was made by NI for FRC. It was made to support LabView, but most certainly does not require it. FIRST/WPI/et al. work in consultation with NI to get the C++/Java versions working equally as well.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 14-01-2017, 15:24
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Check in your services to see if mDNS service is running (or if its listed), it should have been installed when you ran the FRC 2017 update suite.
Can confirm that your computer is properly connecting to the router? You should have an IP address like 10.TE.AM.x (You can see this by opening the command line and typing ipconfig)
As a last case scenario, you could try to install iTunes. (I know it sounds crazy) iTunes has apples Bonjor service, another mDNS responder. You shouldn't need to install this though, if you were to I would only use it as a temporary solution to ensure connectivity.
Unread 14-01-2017, 19:56
FRC #0247
ok, i have installed labveiw, and the bot connects, so long as the rio is the first thing i connect to, however, once i connect to the internet, it can no longer connects to the rio. i do get my ip from the router (most often 10.2.47.107 most often) ive re-flashed the radio and the rio 3 times a piece, we dont have another radio/rio to test at the moment, the ni mdns responder is running and allowed through the firewall, and i have installed bonjior (or however its spells) from itunes.
Unread 14-01-2017, 20:07
FRC #0247
Aha! if i disconect from wifi, disable my wifi chip, enable, then connect to the bot, it works, however if i disconnect and connect to the internet, i cant connect to the rio anymore.
just turning the wireless off and back on doesnt work
