Simple Gear Detection
Here is Team 900's very simple gear detection based off of color and area.
![]() Code:
# basic gear detection from HSV
# 1/14/17
# Team 900 Zebracorns
# Author: Anja S
import cv2
import numpy as np
cap = cv2.VideoCapture(1)
kernel = np.ones((5,5),np.uint8)
while(1):
# Take each frame
_, frame = cap.read()
hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
# Threshold the HSV image
lower = np.array([20, 55, 124])
upper = np.array([48, 255, 247])
mask = cv2.inRange(hsv, lower, upper)
opening = cv2.morphologyEx(mask, cv2.MORPH_OPEN, kernel)
closing = cv2.morphologyEx(opening, cv2.MORPH_CLOSE, kernel)
# Contours
contours = cv2.findContours(closing,cv2.cv.CV_RETR_TREE,cv2.cv.CV_CHAIN_APPROX_SIMPLE)[0]
# Remove contours that don't fit area and HSV constraints
gear_contour = []
for c in contours:
moments = cv2.moments(c)
area = cv2.contourArea(c)
if area < 3000: continue
perim = cv2.arcLength(c, True)
approx = cv2.approxPolyDP(c, 0.00005*perim, True)
if len(approx) > 20:
gear_contour.append(approx)
for x in range(0, len(gear_contour)):
minX = 10000
minY = 10000
maxX = 0
maxY = 0
cx = (minX + maxX)//2
cy = (minY + maxY)//2
# draw box around gear contour
for y in range(0, len(gear_contour[x])):
if gear_contour[x][y][0][0] < minX:
minX = gear_contour[x][y][0][0]
if gear_contour[x][y][0][1] < minY:
minY = gear_contour[x][y][0][1]
if gear_contour[x][y][0][0] > maxX:
maxX = gear_contour[x][y][0][0]
if gear_contour[x][y][0][1] > maxY:
maxY = gear_contour[x][y][0][1]
if gear_contour:
cv2.drawContours(frame, gear_contour, -1, (255, 0, 0),3)
cv2.rectangle(frame,(minX, minY),(maxX, maxY),(255,255,0),3)
cv2.imshow('frame',frame)
k = cv2.waitKey(5) & 0xFF
if k == 27:
break
cv2.destroyAllWindows()
Re: Simple Gear Detection
I always love to see what you guys do with vision processing. Just wondering since it relies on area about how far away can the gear be before it's no longer big enough to be recognized? Also how close?
Very nice, but can you expound on why one would wish to detect a gear?
For catching gears that the human players throw across the field of course.
So you can cheesecake an autonomous routine onto your partner to shimmy their preload gear out of their possession, and onto the floor for your 2-to-3-gear auto?
