Go to Post I'm going to get kicked out of the mentor club for this one... - Not2B [more]
Unread 14-01-2017, 22:26
aflagan aflagan is offline
FRC #1159
aflagan is an unknown quantity at this point
Two drive motors
If I have two drive motors on each side, do I need a separate Talon SRX Speed controller for each motor or can I combine the two motors for one controller? .
Unread 14-01-2017, 22:29
Knufire Knufire is offline
Re: Two drive motors
One per motor, per R35.
R35. Each power regulating device may control electrical loads per Table 8-2. Unless otherwise noted,
each power regulating device shall control one and only one electrical load.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-01-2017, 22:36
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
You can have only one motor to a motor controller. To control both motors you can split PWM wires and feed both controllers, so, motors can run at same (almost) speed
Unread 14-01-2017, 23:30
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
Yes you may use pwm y-splitters to control 2 motor controllers from one pwm port on the roborio.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 15-01-2017, 10:59
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
Since you're using SRX's, I would definitely recommend switching to CAN bus. We used PWM last year (rookie season) with Victor 888's and had some significant issues with it. I think we ended up having to "borrow" two y-cables from other teams at our regional, because ours broke and we had no extras.
CAN has some obvious benefits, like simpler wiring and that you can get temperature and current output data back from the motor controllers.
Switching from PWM to CAN is also quite simple. It took us maybe an hour or two to figure out how to program, and the wiring is easy. It also worked on the first try, which hardly ever happens for me.
