Go to Post I'm now convinced that the entire 2015 season was an elaborate ploy by FIRST to get teams to stop complaining about bumpers. - Joe G. [more]
Unread 14-01-2017, 02:02
YashBrowns's Avatar
YashBrowns YashBrowns is offline
FRC #4763
YashBrowns is an unknown quantity at this point
Smile Shooting Motors and wheels
Our team is new to shooting high goal this year so we just wanted to know what to use for motors and wheels for an working shooter.
So far we have been using a 775 pro motor with a 5:1 gear ratio.
We used the kit of parts andymark wheels for the fly wheels
Unread 14-01-2017, 02:10
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Shooting Motors and wheels
Trial and error.
If you can hook that 5:1 to a speed controller and a computer you can vary speeds and test distance.
Try varying the compression too. The balls will more than likely react a lot to pressure since they are hallow.
There are no instant solutions!
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 14-01-2017, 02:20
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
You're on the right track!
775 Pro's offer a high RPM, and are pretty useful when geared down, like you have.
As for wheels, experimentation is the key-- try using different size wheels, multiple wheels on the same axle (increase in contact surface area), higher traction, just play around with it!
Last year, we used 4'' high traction wheels in a dual fly wheel set up... we had to play around with compression and speeds to get a consistent shot.. this year's a bit different so it's hard to say what works and doesn't.
As SensorZ pointed out, software control is integral in keeping consistent shooter. So I would encourage your programmers to modulate the speeds, and test out what happens!
Good luck!
Unread 14-01-2017, 10:48
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
As a follow-up to the question, does anyone know of any papers/guides on building high shooters?
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 14-01-2017, 10:57
Kyle Heaton's Avatar
Kyle Heaton Kyle Heaton is offline
I like volunteering.
Kyle Heaton will become famous soon enough
The best guide for making new systems is to prototype a lot, and to take inspiration from past robots from previous years.
No paper will ever have the one answer for you, your team, and your needs.
Software Lead Student 2014-2015
Student Technical Lead 2015-2016
Tippecanoe District Winner - Perry Meridian District Winner - District Champs Semifinalists
Kokomo District Quarterfinalists - Dean's List Indiana District Finalist
Arkansas Regional Quarterfinalists - Boilermaker Regional Quarterfinalists
Unread 14-01-2017, 11:03
frodobaggins05's Avatar
frodobaggins05 frodobaggins05 is offline
AKA: Wiring Specialist
FRC #2783
Team Role: Electrical
Rookie Year: 2016
frodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these parts
I agree, and don't forget kids, CHECK YOUR WIRING! )
Unread 14-01-2017, 19:31
YashBrowns's Avatar
FRC #4763
Smile Re: Shooting Motors and wheels
Thanks for all the help, our prototype is shooting 6 out of 12 balls and the rest of overshooting. We r now just adjusting the compression and hood. As most of the comments said it's just trial and error
Unread 14-01-2017, 20:43
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
How are you controlling your motor at the moment? If you're not doing closed loop speed control, you're going to have some difficulty getting good accuracy at a high rate of fire. If you ARE doing closed loop speed control, you want to set your gearing so the motor is spinning at about 50% max speed when you're at your target speed for firing. That'll give you the best control and recovery time.
Unread 15-01-2017, 02:14
YashBrowns's Avatar
FRC #4763
We r just have it hooked from wires to battery
Unread 15-01-2017, 02:18
YashBrowns's Avatar
FRC #4763
We do have vision tracking though if u that's what you mean by a closed loop
Unread 15-01-2017, 02:32
wsh32's Avatar
wsh32 wsh32 is offline
The Nerdiest of the Nerd Herd
AKA: Wesley Soo-Hoo
FRC #0687 (The Nerd Herd)
wsh32 is on a distinguished road
You want to hook up a sensor (encoders, etc) to measure the RPM of your flywheel. Differing flywheel speeds will result in different shots.
FRC 687 - Lead Programmer (2015-2016), Team Captain (2016-present)
Unread 15-01-2017, 02:34
It's not. He's talking about closed-loop speed control.
Open-loop speed control is what you have now. In short, it goes like this:
RIO tells motor: Go this fast
Closed-loop speed control is better for ranging accuracy. It goes like this:
RIO: Motor, go this fast.
Encoder: Hey, RIO, motor is going this fast.
RIO: *checks number from encoder against commanded number* Motor, I need more (or less) speed out of you.
Repeat.
The reason you want closed-loop is to keep the motor at shooting speed as much as possible--stuff being launched tends to slow wheeled shooters until it leaves the "muzzle".
Unread 15-01-2017, 11:42
DonRotolo's Avatar
Back to humble
FRC #0832
This is not ideal.
As a first whack, OK (despite the very big lack of safety), but now at least get a big fuse or circuit breaker in there.
Very much preferred at this stage - a week in - is to have the RoboRIO controlling it through a motor controller. This way you can:
1. Adjust the speed very finely so accuracy is spot-on
2. Use a speed sensor on the motor or wheel to (try to) keep the wheel speed constant, so ball #12 goes to the same spot as ball #1.
3. Get a better idea of what you will see in reality when the robot is actually doing the controlling (The motor controller doesn't give as much voltage to the motor as a direct connection might).
All of these point more towards success. Yes they require effort, but do you want to win or watch?
Unread 15-01-2017, 12:00
YashBrowns's Avatar
FRC #4763
So looking up an encoder will control the speed of the wheels and motor which will help increase accuracy
Unread 15-01-2017, 12:20
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
775 pro motors are excellent motors for shooters. One very important thing about them is they need to be spinning for the fans to cool them. If they stall, they will fry in ~4 seconds according to Vex. They are high speed and high power, but keep them spinning! Even if you stall them for two or three seconds it may result in the motors having reduced power output or speed permanently. My team had some problems with our shooter shooting low last year and we found that our motors were partially damaged.
