Go to Post I have long since given up on these hints, and come to the conclusion that they are designed to befuddle us all and amuse Dave. - Rickertsen2 [more]
Unread 14-01-2017, 14:42
NotVerySwift NotVerySwift is offline
FRC #4665
NotVerySwift is an unknown quantity at this point
Angled Bumpers
For our robot, we wanted a ball pickup system for balls on the ground to be added to our ball storage system. We are running it non-stop, so we wanted the whole front end to be an intake. The bumpers get in the way and leave only about 10 inches for the intake. We were wondering if we could have the front corner bumpers at a 70 degree (or smaller) angle instaed of a right angle. The Rules, as far as we know, don't mention the angle of bumpers, but all the images of bumpers show right angles. We wanted to make it a funnel to go into the intake.
Unread 14-01-2017, 15:09
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Angled Bumpers
If you wrap a piece of string around your ROBOT and pull it taut, that defines the FRAME PERIMETER that the BUMPERS need to be attached to.
This means the angles of the frame cannot be less than 90 degrees, because you would then have a piece of that tightly pulled string that was flapping in the air without a place to attach a BUMPER.
(since 2004)
Unread 14-01-2017, 15:46
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Re: Angled Bumpers
All corners do not need to be 90 degrees. You must meet - R22.
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 6 in. (~16 cm) of BUMPER must be placed on each side of each outside corner (see Figure 8-1). If a FRAME PERIMETER side is shorter than 6 in. (~16 cm), that entire side must be protected by BUMPER (see Figure 8-2).
Unread 14-01-2017, 17:06
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: Angled Bumpers
I think what you are asking is.
Can we angle the bumper at the opening to the intake to help game elements funnel into the robot / intake system?
I believe this rule answers this scenario.
I am paraphrasing....
R29.
BUMPERS must be constructed as follows .
a) backed by 3/4" robust wood.
c)stacked pair of 2.5" pool noodle
Having an angle at the bumper opening will no longer provide the 2.5" of pool noodle required..
Of course keeping in mind all the other bumper rules including those mentioned above.
Good luck this season
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 14-01-2017, 19:10
Re: Angled Bumpers
Someone posted a CAD render on DAY 1 with the configuration mentioned. It's going to be a long year for the inspectors...
A legal configuration for legal bumpers includes the following relevant items:
R22: 6" on either side of a corner in the Frame Perimeter (not necessarily the robot's frame--wrap a rubber band around the frame instead of string, maybe?)
R29G: Secure attachment to Frame Perimeter
Now, the described configuration fails to meet R29G, as it's not on the Frame Perimeter, and fails to meet R22 because it's not protecting the corners of the Frame Perimeter.
Unread 15-01-2017, 07:58
volunteer helper
FRC #6099 (Knights)
Re: Angled Bumpers
Sorry - I was thinking that you meant the entire bumper assembly and not just the foam noodle part of it.
If you are strictly talking about angling the ends of the foam noodles themselves, instead of cutting the foam off relatively square at the end of the bumper - that would violate the 2 1/2" bumper requirement.
The end would be covered by less and less foam as the angle approaches the backing wood, which violates the 2 1/2" of foam requirement.
Unread 15-01-2017, 11:35
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Angled Bumpers
Yes indeed. Welcome to the 2017 game.
Unread 15-01-2017, 12:13
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Angled Bumpers
Your best bet if you want a full-front intake is to make your robot intentionally short and build an intake that deploys over top of the bumpers to collect balls.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 15-01-2017, 12:41
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Angled Bumpers
Asked on Q and A: https://frc-qa.firstinspires.org/qa/136
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 17-01-2017, 17:18
FRC #4665
Re: Angled Bumpers
I was actually talking about the entire bumper system. We were going to angle the robot frame and the bumper backings to make the balls roll inward.
Unread 17-01-2017, 18:29
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Angled Bumpers
I suggest you reread the rules regarding bumpers and the frame perimeter, then reread GaryVoshol's post, and then watch this video. Note that the video references a 120" frame perimeter limit, which is an old rule and does NOT apply to this year's competition. However, it's a good explanation of the frame perimeter.
The answer to your initial question is no; you cannot have convex faces in your frame perimeter simply by the definition of a frame perimeter by the rules.
Unread 17-01-2017, 19:10
Re: Angled Bumpers
I would put your odds of getting through inspection that way at about 5%, and your odds of having to be reinspected within a match or two at 99% when someone comments about it.
The big key here is: Frame Perimeter != robot frame. If you look at the attachment, the blue line is your robot frame as described. The red line is your Frame Perimeter. Bumpers are located on, and attach to, the Frame Perimeter.
Name:	Perimeter Explanation.jpg
Unread 24-01-2017, 22:03
jjb.bailey jjb.bailey is offline
FRC #2404
Team Role: Parent
Rookie Year: 2015
jjb.bailey is an unknown quantity at this point
Re: Angled Bumpers, concave design
We at Team TNT2404 think we can use a concave design. Please check our image link above. It's a quick drawing to show "the maw"; we will have bumpers around perimeter as required. See Figure 8-1 in the 2017 Manual and description of Example following R01. Based on those figures and examples, we would like to know which rule the attached "concave" design might be breaking.
jjb.bailey
Mentor-rookie year
Parent-third year
Unread 24-01-2017, 22:25
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
jjb.bailey
Mentor-rookie year
Parent-third year
Image broken
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 24-01-2017, 22:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Ari423 View Post
Image broken
Here's the image:
If the blue part is actual robot frame, then no, this is NOT legal. Those aren't bumpers, because they're not on your frame perimeter. Your frame perimeter is a straight line that goes from one side of that opening to the other. In that drawing, your frame perimeter is basically a square. And you need bumpers for atleast 6 inches in both directions on each and every corner of that square, supported at both ends by robot structure.
Again, your drawing there won't pass inspection and you'll be making major changes to your robot on Thursday. Please don't do it.
