Go to Post Apparently he felt that wearing ringers is akin to "being surrounded by safety." - DanDon [more]
Unread 19-12-2016, 02:27
Mustafa Mert's Avatar
Mustafa Mert Mustafa Mert is offline
AKA: Mustafa Mert Tunalı
FRC #6416 (MEV Makers)
Rookie Year: 2015
Mustafa Mert is an unknown quantity at this point
Unhappy Image Proccesing- LabVIEW
Hi everyone. I have a problem with Image Proccesing. how can i use image proccesing on autonomous? I have watched all videos on youtube but i couldnt understand.
Unread 19-12-2016, 02:44
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Re: Image Proccesing- LabVIEW
There are several ways to process images (e.g. in the robot LabVIEW code, in the LabVIEW dashboard, GRIP, roborealm, etc.). Which one are you using?
Unread 19-12-2016, 06:07
Rookie Year: 2015
I'm using LabVIEW Code. I have seen LabVIEW Dashboard but i dont know where i should start for that.
Unread 19-12-2016, 11:26
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
The vision processing algorithm really shouldn't change between auto and tele-op. Really, if you have an automated feature in tele-op for aiming, even the robot motion shouldn't be different.
I'm not going to recommend the dashboard, as it introduces latency into your images (there are ways to fix it, but it's harder), but I did it that way in the offseason so here goes:
  1. Filter out your surrounding box. You can use a variety of color filters, shape filters, etc.
  2. Get the info from this box - center, etc.
  3. Process that info to get how much you need to turn, distance.
  4. Send this info to the robot.
  5. Move the robot to desired angle/distance.
If you need help, you can PM me.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 14-01-2017, 17:54
See Tutorial 8 in the Tutorials tab on the LabVIEW Getting Started page.
Unread 15-01-2017, 09:03
xszym's Avatar
xszym xszym is offline
FRC #5883
Rookie Year: 2016
xszym is an unknown quantity at this point
Exactly. In FRC Examples you can see how to analyze the image with LabView
