Go to Post FIRST competitions ARE holidays, or they should be at least. - Kel D [more]
Unread 14-01-2017, 12:29
Repasky379's Avatar
Repasky379 Repasky379 is offline
AKA: Matt
FRC #0379
Repasky379 is an unknown quantity at this point
Problem Connecting with OM5P-AC Radio
After imaging the roboRIO and updating the firmware on the radio, we tried to upload code through labVIEW. However, we weren't able to connect to the robot to upload code.
The laptop we are using connects to the robot, as we can connect to the network. When connecting through the dashboard, the communications indicator on the dashboard is green, but code is red.
The wifi light on the radio is solid yellow, the comm indicator on the roboRIO is solid red.
We configured the radio using the newest configuration tool, we tried methods suggested in other threads such as putting a name in the optional robot name section of the tool and turning off IPv6 connectivity. Pinging the RIO doesn't give us any results either.
If anyone has any suggestions, please let us know.
Unread 14-01-2017, 20:45
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Problem Connecting with OM5P-AC Radio
Have you followed R63?
Unread 14-01-2017, 22:29
From your description it sounds like your radio is fine and the roboRIO is fine.
Check your LabVIEW project explorer window to insure that your team number is entered correctly (see attached example).
You can test by connecting your PC directly to the roboRIO via a USB cable, however you must change the project Target from "roboRIO-####-FRC.local" to "172.22.11.2" in order to Run as startup over the USB connection.
Unread 15-01-2017, 10:13
Repasky379's Avatar
AKA: Matt
FRC #0379
This was likely the problem, as we were able to upload code when we switched laptops. Thanks!
