Go to Post everybody wants a piece of success! - Taylor [more]
Unread 14-01-2017, 16:58
JasdeepSadam JasdeepSadam is offline
FRC #2656 (Quasics)
Team Role: Driver
Rookie Year: 2016
JasdeepSadam is an unknown quantity at this point
Best wheel for Torque?
I was planning on having very high torque wheels that still have a decent amount of speed for climbing the rope this year. Does anyone know a good wheel type that could fulfill these requirements? I was thinking Plaction Wheels from AndyMark, but I am not sure.
THANKS
Unread 14-01-2017, 17:04
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Best wheel for Torque?
The amount of torque and speed you get depends on your motor choice and gearing. I don't believe the type of wheel you choose has anything to do with how much torque you get out.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 14-01-2017, 17:47
doot doot
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Correct!
Try playing with JVN's Mechanical Design Calculator in the linear mechanism tab on the bottom of the sheet. You can enter the motor you plan to use, its reduction, the weight it has to lift, and the distance it needs to go and it'll give you ballpark numbers of how long it will take to lift and how much its capable of lifting.
Unread 14-01-2017, 17:49
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Well the smaller the wheel, the most torque you have. If you are talking about traction, a pneumatic wheel usually has a lot, but they are usually very large. But the major factor of how much torque you have is your gearbox, which is usually geared around what size of wheels you have. I may be wrong, but most teams decide their wheel size, the speed desired mechanism, then what gearing it takes.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 15-01-2017, 16:05
darrellt darrellt is offline
FRC #2635
darrellt is an unknown quantity at this point
You can use this online tool to model and analyze your motors, gearboxes, and winch size to calculate how long it will take to lift your robot and if you are at risk of tripping the breaker by drawing too much current.
Here is an example
