Go to Post Replay/video isnt a BAD idea, its just not a GOOD idea for FIRST. - Ashley Christine [more]
Unread 15-01-2017, 16:01
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Java deploy not working
I recently installed Windows 10 (clean install) on our programming laptop and after following the usual steps to install Eclipse and the WPILib plugins, I can't get the code to deploy to the RoboRIO. When I do the "Run As->WPILib Deploy" the console window pops up, but no messages appear at all and the code isn't getting downloaded.
Things I have tried:
  • Make sure that Eclipse is pointed at a JDK, not JRE
  • Tried both wired and wireless connections to the modem
  • Tried turning off Windows Firewall (although it looked like the settings were correct to let everything needed through)
  • Tried connecting wirelessly and disabling the wired ethernet hardware
I know the RoboRIO and modem are set up correctly as I was successfully downloading code before the new install of Windows 10 (it was using Windows 8 before).
Ideas? Suggestions? At this point I am ready to uninstall Eclipse and reinstall it again to see if that makes a difference.
Thanks
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 15-01-2017, 16:13
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Re: Java deploy not working
I have had similar issues and found that uninstalling eclipse did not help.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
