Go to Post Analysis is a tool. Like any other tool you need to figure out where and when to use it. That's the tricky part. - ChrisH [more]
Unread 15-01-2017, 18:35
blturner blturner is offline
FRC #5013 (Trobots)
blturner is on a distinguished road
Re: 3D Printed Gearbox for Denso Throttle Motor Available
I 3D printed a gear for this motor for aerial assist. I was trying to get as compact as possible and could not get enough reduction in the space allowed, so I used a ring gear on a flat plate. Regular ring gears are expensive, seldom available in the size you want and can't be made on a flat plate. The ring gear also makes a slightly stronger contact area.
The gear is sized to mount on a 1/4 inch bolt centered in a 1 inch square tube. I strapped the motor to the tube with a hose clamp and some double faced tape.
It was not strong enough for handling the huge balls in aerial assist but would have no problem with this years small ones.
I would also like to see a gearbox that matched the mount holes of the versa planetary but that might be too compact.
As to the usefulness of this gearbox/motor verses the more powerful ones. Most teams can 3D print this for less than 1/4 the cost of a versaplanetary and you can stall this motor for a lot longer than a 775pro.
Name:	ring gear15hole.png
