Go to Post (Funding will be plentiful...) Where is this magical land? We can move our team there! - Tungrus [more]
Unread 15-01-2017, 18:27
andrewytiger andrewytiger is offline
FRC #3929
andrewytiger is an unknown quantity at this point
Actively Placing Gears
I know there are several questions that have already been answered on the Q&A system about this, but they have been so vague and I still don't know if this is legal. Are we allowed to use an active mechanism to release the gear or not? For example, can we push the gear onto the peg using a piston when the peg is inside of our robot's bumpers?
Unread 15-01-2017, 18:29
FRC #3929
Re: Actively Placing Gears
Here's a link to a video and photos of what I mean: https://goo.gl/photos/QXdRCiNtoXF5xu1M9
Unread 15-01-2017, 18:31
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I haven't seen anything that says that it wouldn't be legal; is there a reason you think it might be illegal? As long as the piston always stays inside the robot volume, you should be fine.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 15-01-2017, 18:33
FRC #3929
I'm worried this may be called throwing which would be considered illegal.
Unread 15-01-2017, 18:43
Ari423's Avatar
FRC #5987 (Galaxia)
This rule (like many others) relies on a judgement call from the refs. I'd say that as long as your robot is always in contact with the gear until it is fully supported by the lift (i.e. it's always either touching the robot or the lift), you won't get called on throwing. If your piston is moving fast enough to throw the gear out of the robot (or even make it look like it's being throw even if it's not), try lowering the pressure.
2013: Programmer
Unread 15-01-2017, 19:10
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
You could also use something like this
http://www.andymark.com/product-p/am-2897.htm
Unread 15-01-2017, 19:31
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Q96 seems to answer this.
You appear to have a valid case that you're not shooting in the air, kicking across the floor, rolling across the floor, or throwing - you're pushing. [G23]'s definition of LAUNCHING as applied to putting a gear onto the peg implies the gear was, at some point, not touching either the robot or the peg. You'll likely want to clear the actions with your head ref at the event though.
https://frc-qa.firstinspires.org/qa/96
GitHub
