You're a keeper.
Unread 14-01-2017, 12:38
Mock_1 Mock_1 is offline
FRC #3570
Mock_1 is an unknown quantity at this point
Need Some Clarification of Rule G27
Is it saying that you can not have a gear in the area showed or can you just not have two gears in that area?
Unread 14-01-2017, 13:04
Musketeer Musketeer is offline
FRC #4006 (C.I-Borgs)
Team Role: Student
Musketeer is an unknown quantity at this point
Re: Need Some Clarification of Rule G27
my team's understanding of G27 is that only one gear is allowed to be touching the robot itself during a match. If more than one gear is touching the robot at a time, then it counts as a violation of the rule. Hope this helps!
Unread 14-01-2017, 13:19
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
A. “bulldozing” (inadvertent contact with GEARS while in the path of the
ROBOT moving about the FIELD)
B. “deflecting” (being hit by a GEAR that bounces into or off of a
ROBOT).
These are the only conditions in which a second gear can touch your bot.
Unread 14-01-2017, 13:22
Tungrus Tungrus is offline
Tungrus is a name known to allTungrus is a name known to allTungrus is a name known to allTungrus is a name known to allTungrus is a name known to allTungrus is a name known to all
You cannot posses more than one gear. It's considered as possession when your robot is carrying more than one great or carrying one gear and pushing another one. Running over a gear is not possession, on less the gear moves. This girl s my understanding of rule and Q&A clarification.
Unread 14-01-2017, 15:19
GaryVoshol's Avatar
Cogito ergo arbitro
ROBOT).
Note the line immediately above the two that you quoted from the G27 blue box:
Examples of interaction with GEARS that are not “control” include, but are not limited to:
(emphasis mine)
So while those are 2 conditions that do not constitute possession, those may not be the only 2 conditions.
(since 2004)
Unread 15-01-2017, 19:18
FRC #3570
So your allowed to have a gear on top of your robot as long as you don't have two, right?
Unread 15-01-2017, 19:21
Yep.
Unread 15-01-2017, 19:26
FRC #3570
Yep.
Ok thanks, because we had people interrupt it as you had to carry the gears outside the box as shown in rule G04.
Unread 15-01-2017, 19:34
May want to have those people read Q68's answer at https://frc-qa.firstinspires.org/qa/68.
Unread 15-01-2017, 19:44
FRC #3570
Ok thanks again
