Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 14-01-2017, 19:58
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
Simple Gear Detection
Here is Team 900's very simple gear detection based off of color and area.
# basic gear detection from HSV
# 1/14/17
# Team 900 Zebracorns
# Author: Anja S
import cv2
import numpy as np
cap = cv2.VideoCapture(1)
kernel = np.ones((5,5),np.uint8)
while(1):
	# Take each frame
	_, frame = cap.read()
	hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
	# Threshold the HSV image
	lower = np.array([20, 55, 124])
	upper = np.array([48, 255, 247])
	mask = cv2.inRange(hsv, lower, upper)
	opening = cv2.morphologyEx(mask, cv2.MORPH_OPEN, kernel)
	closing = cv2.morphologyEx(opening, cv2.MORPH_CLOSE, kernel)
	# Contours
	contours = cv2.findContours(closing,cv2.cv.CV_RETR_TREE,cv2.cv.CV_CHAIN_APPROX_SIMPLE)[0]
	# Remove contours that don't fit area and HSV constraints
	gear_contour = []
	for c in contours:
		moments = cv2.moments(c)
		area = cv2.contourArea(c)
		if area < 3000: continue
		perim = cv2.arcLength(c, True)
		approx = cv2.approxPolyDP(c, 0.00005*perim, True)
		if len(approx) > 20:
			gear_contour.append(approx)
		for x in range(0, len(gear_contour)):
			minX = 10000
			minY = 10000
			maxX = 0
			maxY = 0
			cx = (minX + maxX)//2
			cy = (minY + maxY)//2
			# draw box around gear contour
			for y in range(0, len(gear_contour[x])):
				if gear_contour[x][y][0][0] < minX:
					minX = gear_contour[x][y][0][0]
				if gear_contour[x][y][0][1] < minY:
					minY = gear_contour[x][y][0][1]
				if gear_contour[x][y][0][0] > maxX:
					maxX = gear_contour[x][y][0][0]
				if gear_contour[x][y][0][1] > maxY:
					maxY = gear_contour[x][y][0][1]
			if gear_contour:
				cv2.drawContours(frame, gear_contour, -1, (255, 0, 0),3)
				cv2.rectangle(frame,(minX, minY),(maxX, maxY),(255,255,0),3)
	cv2.imshow('frame',frame)
	k = cv2.waitKey(5) & 0xFF
	if k == 27:
		break
cv2.destroyAllWindows()
Unread 14-01-2017, 20:14
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Simple Gear Detection
I always love to see what you guys do with vision processing. Just wondering since it relies on area about how far away can the gear be before it's no longer big enough to be recognized? Also how close?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 15-01-2017, 11:52
DonRotolo's Avatar
Back to humble
FRC #0832
Very nice, but can you expound on why one would wish to detect a gear?
Unread 15-01-2017, 21:29
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
For catching gears that the human players throw across the field of course.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 16-01-2017, 09:22
Billfred's Avatar
Billfred Billfred is offline
So you can cheesecake an autonomous routine onto your partner to shimmy their preload gear out of their possession, and onto the floor for your 2-to-3-gear auto?
