Go to Post "well.. I think I underestimated the swine..." -Andy Baker - Joel J [more]
Unread 15-01-2017, 14:12
Caleb O's Avatar
Caleb O Caleb O is offline
FRC #1825 (Metro Homeschool Robotics)
Rookie Year: 2015
Caleb O is an unknown quantity at this point
command based, gyro, omnidrive
hi i am wondering if there is any team, or example code, out there that has (command based) programmed a robot, which has an omnidrive system with a gyroscope. The gyroscope would be used for making the robot "think" that forward is always the same direction no matter the orientation of the robot. Sort of like forward is always forward relative to the driver station. Thanks in advance.
Unread 15-01-2017, 22:10
Caleb O's Avatar
Rookie Year: 2015
Re: command based, gyro, omnidrive
if no one can find anything like this is there something that has at least omni drive with a gyro out there? and if so please post the link
Unread 15-01-2017, 22:14
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Can you be more specific when you say omni drive?
If swerve fits your definition of omni drive then you can have a look at our 2014 code https://github.com/Frc2481/frc-2014/...DriveTrain.cpp Lines 54 - 58 will be most interest.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 15-01-2017, 22:46
SamCarlberg's Avatar
SamCarlberg SamCarlberg is online now
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
If you're using mecanum wheels or omni wheels at 45 degree angles, you could use
RobotDrive::MecanumDrive_cartesian(x, y, rotation, gyroAngle)
WPILib
GRIP, RobotBuilder
Unread 15-01-2017, 22:48
Caleb O's Avatar
Rookie Year: 2015
like these omni wheels: http://www.andymark.com/Omni-p/am-0123.htm
Unread 15-01-2017, 22:53
FRC #2084
Are they mounted like this:
or like this:
because the second one can use the mecanum drive code.
WPILib
GRIP, RobotBuilder
Unread 16-01-2017, 00:40
Caleb O's Avatar
Rookie Year: 2015
it is kinda a custom drive train but it might work with the second one. sorry for the horrible drawing but that is what ms paint gives me: https://www.dropbox.com/s/lz4ow5kgpqaw9vv/omni.png?dl=0
Unread 18-01-2017, 20:35
Penchant Penchant is offline
FRC #4607
Rookie Year: 2015
Penchant has a spectacular aura aboutPenchant has a spectacular aura about
I have done programming with similar systems, and if you are looking for how to make it field centric rather than robot centric, I just took in the joystick values as polar coordinates, which is a magnitude and direction, then converted them to cartesian coordinates but in the conversion process adjusted the angle by the angle of the gyro.
So a snippet of the code:
adjustmentAngle = gyro->GetAngle()*3.14/180+3.14/2;
x=Pilot->GetMagnitude()*cos(Pilot->GetDirectionRadians()-adjustmentAngle);
y=Pilot->GetMagnitude()*sin(Pilot->GetDirectionRadians()-adjustmentAngle);
Unread 19-01-2017, 08:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Using the Mecanum code but rotating everything by 45 degrees may give acceptable performance. Something like:
RobotDrive::MecanumDrive_cartesian((x+y)/2, (x-y)/2, rotation, gyroAngle)
Unread 19-01-2017, 10:24
Pick any point O, usually at or near the center of geometry of the wheel contact patches. That will be your center of rotation.
Then the inverse kinematics are given by:
S1 = STR + |y1|*Ω
S2 = FWD + |x2|*Ω
S3 = STR - |y3|*Ω
S4 = FWD - |x4|*Ω
...where:
Sn are the wheel speeds (linear speed at the wheel circumference)
FWD is the vehicle forward speed command
STR is the vehicle strafe right speed command
Ω is the vehicle rotate clockwise command in radians/sec about the point O
all variables (Sn, xn, yn, FWD, STR) must use the same dimensions (e.g feet, inches, meters, etc) for the linear part
