Go to Post After all, life is what you do outside of FIRST. No wonder it's so short. - Vashts6583 [more]
Unread 15-01-2017, 00:16
Eric_Dao Eric_Dao is offline
FRC #6397
Rookie Year: 2017
Eric_Dao is an unknown quantity at this point
Use both joysticks to drive robot on Xbox controller?
How can I use both thumb sticks on an Xbox controller to move the robot's left and right motors?
Unread 15-01-2017, 02:01
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Use both joysticks to drive robot on Xbox controller?
robotDrive.tankDrive(xboxController.getRawAxis(1), xboxController.getRawAxis(3))
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 15-01-2017, 11:48
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
You can also try this:
robotDrive.tankDrive(xboxController.getY(Hand.kLeft), xboxController.getY(Hand.kRight));
Unread 15-01-2017, 16:00
18gillespiery 18gillespiery is offline
FRC #6421
18gillespiery is an unknown quantity at this point
What we did was define two variables as joysticks on the same port
From there use the Joystick.setChannel() method to change it to the y axis on the other stick. It should be channel 5.
after that it should work.
Unread 15-01-2017, 23:40
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Sorry, I'm a bit confused about what you're doing.
Bad idea. Why do you need to do this?
Can you post your code please?
Unread 15-01-2017, 23:48
AKA: אוסטין
What 18gillespiery recommends is below. I do not recommend teams do this. Instead use either of the examples above.
Once again, this code is not recommended!
public class Robot extends IterativeRobot {
	private RobotDrive drive;
	private Joystick joystick1;
	private Joystick joystick2;
	@Override
	public void robotInit() {
		drive = new RobotDrive(0, 1);
		joystick1 = new Joystick(0);
		joystick2 = new Joystick(0);
		joystick2.setAxisChannel(AxisType.kY, 5);
	@Override
	public void teleopPeriodic() {
		drive.tankDrive(joystick1, joystick2);
Unread 16-01-2017, 08:17
FRC #6397
Rookie Year: 2017
Okay, thank you all for your help!
