Go to Post before you post, ask yourself: Is there a good reason to post this? - Jeff Waegelin [more]
Unread 16-01-2017, 10:40
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: FRC Bearing Load Ratings (Climber Winch)
I agree with the request/focus on bearing ratings, but I'd be less concerned about bearings on a simply-supported climber shaft failing than I would a wheel bearing, particularly in a WCD-type application. The climber shaft should see very low (if any?) dynamic loading, where-as the drivetrain bearings will often see a wide variety of dynamic loadings... even if the climber never falls and the robot lands on its wheels. ;-) Additionally, the drivetrain bearings experience a lot more cycles/use given that they're used almost continuously during the match and are often turning at higher speeds.
Regardless, it'd be good to use more than experience from other applications!
Originally Posted by Lil' Lavery View Post
... With many of the winch-based climber designs, many teams are going to be supporting the weight of their robot with two bearings. While hex bearings have been used for supporting drivetrain loads, that robot weight has been split among four or more axles and eight or more bearings. I'm curious if teams are going to be getting themselves into trouble with bearing loads on their climber winches....
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
