Re: Beginning Vision Processing
So where would you suggest starting with this sample of code. More specifically which object could I use in this sample code to retrieve a live image from and begin processing? I am having trouble determining how to retrieve the live image.
Also when generating code from GRIP did it look anything like this sample? Thank you for your suggestions! import edu.wpi.cscore.AxisCamera; import edu.wpi.cscore.CvSink; import edu.wpi.cscore.CvSource; import edu.wpi.first.wpilibj.CameraServer; import edu.wpi.first.wpilibj.IterativeRobot; import org.opencv.core.Mat; import org.opencv.core.Point; import org.opencv.core.Scalar; import org.opencv.imgproc.Imgproc; /** * This is a demo program showing the use of OpenCV to do vision processing. The * image is acquired from the Axis camera, then a rectangle is put on the image and * sent to the dashboard. OpenCV has many methods for different types of * processing. */ public class Robot extends IterativeRobot { Thread visionThread; @Override public void robotInit() { visionThread = new Thread(() -> { // Get the Axis camera from CameraServer AxisCamera camera = CameraServer.getInstance().addAxisCamera("axis-camera.local"); // Set the resolution camera.setResolution(640, 480); // Get a CvSink. This will capture Mats from the camera CvSink cvSink = CameraServer.getInstance().getVideo(); // Setup a CvSource. This will send images back to the Dashboard CvSource outputStream = CameraServer.getInstance().putVideo("Rectangle", 640, 480); // Mats are very memory expensive. Lets reuse this Mat. Mat mat = new Mat(); // This cannot be 'true'. The program will never exit if it is. This // lets the robot stop this thread when restarting robot code or // deploying. while (!Thread.interrupted()) { // Tell the CvSink to grab a frame from the camera and put it // in the source mat. If there is an error notify the output. if (cvSink.grabFrame(mat) == 0) { // Send the output the error. outputStream.notifyError(cvSink.getError()); // skip the rest of the current iteration continue; } // Put a rectangle on the image Imgproc.rectangle(mat, new Point(100, 100), new Point(400, 400), new Scalar(255, 255, 255), 5); // Give the output stream a new image to display outputStream.putFrame(mat); } }); visionThread.setDaemon(true); visionThread.start(); } } |
