Go to Post Remember, FIRST is about people. Robots are just what bring us all together... - Matt Attallah [more]
Unread 16-01-2017, 14:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Machining precision required to make custom gearboxes
Originally Posted by FrankJ View Post
If you don't have a CNC or a manual mill, you can do this manually. With the typical FRC gears and a simple gear box. you can lay out and drill holes using a machinist scale, scribe, prick punch, a drill press, and a little OCCD. Clamp & drill the side plates together. This takes a lot of care, but is very doable.
While what you describe certainly could be done by someone with very steady hands, good eyesight, and great attention to detail, I would argue that any team which only has a drill press shouldn't be considering building custom gearboxes given the plethora of great COTS options available.
Much more valuable to expend that effort on other areas of the robot.
2001-2004: Team 100
2006-Present: Team 254
