Go to Post Although I have much yet to go, in my short time in FIRST I have learned there is no such thing as a waste of time, especially when a) fundraising, b) mentoring students, or c) reading directions. - Amanda Morrison [more]
Unread 15-01-2017, 16:27
Cog Cog is offline
FRC #3324 (The MetroBots)
Cog will become famous soon enoughCog will become famous soon enough
Machining precision required to make custom gearboxes
My team is currently making a (simple) custom gearbox in place of the COTS gearboxes we were planning to use that ran out of stock.
My question is: Do you really need thou precision to make decent gearboxes? Because after looking at some other threads, it seems like even measurements as small as .003" can make a significant difference in the performance of a gearbox.
Unread 15-01-2017, 16:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Machining precision required to make custom gearboxes
I would say you should be able to relatively easily hold .002" on position of hole centers on a decent quality manual mill with a somewhat experienced operator. That would be good enough for a custom gearbox.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2017, 17:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
What about oblong holes? Our DIY gantry-style CNC consistently cuts oblong bearing holes that are exactly correct in the 'X' direction, but approximately 0.001-0.002 off in the 'Y' direction. That's about as close as they could get before needing to move on to other things.
As the guy CAD'ing our first-ever custom (non-drivetrain) gearboxes this year, is there anything I can do to make this a non-issue? The concern for us is gearbox longevity in ~120 matches between March & November.
GitHub
Unread 15-01-2017, 17:36
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Your probably going to be fine, the 20DP gears commonly used in FIRST are purposely larger than necessary so they can handle being abused in low precision gearboxes and high sudden torque situations. Usually the failures of gears in FIRST are either due to gears being too small and cracking at propagated stress points of the hex shaft or flexing and allowing the gear mesh to become far too loose (the VEX Ball shifter 3rd stage seems to have this issue). In the scheme of things the amount of time FIRST robots run is very short and wearing your gears to the point of failure is very unusual unless something is really wrong like the mesh being too tight. This why its common to add .002" to the C-C mesh of gears in FIRST.
2016: FRC 865 Mentor
Unread 16-01-2017, 02:36
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Originally Posted by mman1506 View Post
Your probably going to be fine, the 24DP gears commonly used in FIRST are purposely larger than necessary so they can handle being abused in low precision gearboxes and high sudden torque situations. Usually the failures of gears in FIRST are either due to gears being too small and cracking at propagated stress points of the hex shaft or flexing and allowing the gear mesh to become far too loose (the VEX Ball shifter 3rd stage seems to have this issue). In the scheme of things the amount of time FIRST robots run is very short and wearing your gears to the point of failure is very unusual unless something is really wrong like the mesh being too tight. This why its common to add .002" to the C-C mesh of gears in FIRST.
Quick correction: gears in FRC are 20DP (which is actually a very odd pitch for some reason, most sites only sell 16p or 24p) and are actually way undersized. If you compared the tooth of a Vex gear to that of a Boston Gear gear, you'll notice that the Vex teeth are slightly thinner and have large sections of the root of the tooth taken out.
I second that you need .002" precision at the minimum. Personally I prefer .001". If you do not have a mill, please don't attempt this mid-season- there is almost a saturation of gearboxes available from WCP, Vex, and Andymark.
Unread 16-01-2017, 10:01
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Do you have backlash or is it just lead error? Can you program backlash compensation into the machine configuration?
Unread 16-01-2017, 10:23
JesseK's Avatar
FRC #1885 (ILITE)
I do not know, but I will ask those questions. They spent about 6 hours re-calibrating a new bit Saturday, but since I was knuckles-deep in drive train gearboxes I don't know the specifics.
GitHub
Unread 16-01-2017, 11:02
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If you don't have a CNC or a manual mill, you can do this manually. With the typical FRC gears and a simple gear box. you can lay out and drill holes using a machinist scale, scribe, prick punch, a drill press, and a little OCCD. Clamp & drill the side plates together. This takes a lot of care, but is very doable.
Unread 16-01-2017, 14:17
Cory's Avatar
AKA: Cory McBride
While what you describe certainly could be done by someone with very steady hands, good eyesight, and great attention to detail, I would argue that any team which only has a drill press shouldn't be considering building custom gearboxes given the plethora of great COTS options available.
Much more valuable to expend that effort on other areas of the robot.
2001-2004: Team 100
Unread 16-01-2017, 14:43
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Are there any other teams in your area that have access to a CNC mill or water-jet? Most teams are happy to support other nearby teams with machining or needed parts. FIRST is really a community, we only compete on the field.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 16-01-2017, 14:52
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
A little OCCD
A lot of OCD and a quality drill press. Even with the plates clamped together, our drill press isn't straight/rigid enough for me to be comfortable with 841 trying this [with aluminum gears].
Yes. Highly recommend finding the extra ~$100-200 to buy-not-build.
...oblong holes...
Consider milling undersize and finishing with a 1.1250" reamer - biting the bullet and getting a reamer has allowed 841 to use our not-super-rigid benchtop tools to rough out bearing holes at the right location (on say a WCD rail or mechanism arm) quickly and a little undersized, and then finish the holes to a really nice bearing fit.
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 16-01-2017, 14:58
protoserge's Avatar
That is how I have done this in the past to deal with our Taig cnc. I grabbed a 1.124 reamer off eBay that I'd like to try.
I would venture to think that there is backlash in the router that can be corrected with software (LinuxCNC/Mach/etc.), but I haven't seen their setup.
Unread 17-01-2017, 10:49
JesseK's Avatar
FRC #1885 (ILITE)
I believe the calibration issue we're seeing with the x/y is in the machine code processor. Things can also get a little messed up if there is debris in the rack and pinion drives. Just haven't had an opportunity to tease it out yet.
We do have a reamer, but have had mixed results when using it on oblong holes. Using a micrometer on a sample after under-sizing still shows a position margin of error of around +/- 0.001 in a dimension.
In any event, since the gears arrive tomorrow we'll likely just make the gearbox and report back in November. If we see signs of premature wear during our planned 50-climb test, we'll probably get steel gears and just brute force it. It's in an easy-to-replace spot and we're building a spare as it is.
GitHub
Unread 17-01-2017, 11:02
protoserge's Avatar
On a DIY setup, that's pretty respectable. You could try running a spring/multiple finishing passes to see if that helps remove hole eccentricity.
Unread 17-01-2017, 11:37
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
I agree that you are better of buying the solution when one is available. The COTs choices have grown tremendously in the last few years. But one stage is fairly easy with 20 DPI gears. More than 2 stages becomes really difficult. I always take stated accuracies with a grain of salt.
In terms of drill presses. We are fortunate to have a heavy 1/2 press with good bearings. But I get as accurate results by using a 1/4 in Ryobi and either a short 1/8" bit or center bit.
