You may possess me without penalty.
Unread 16-01-2017, 14:19
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Rope - Multiple Loops
Based on
https://frc-qa.firstinspires.org/qa/148
Question
Is there a prohibition from having multiple loops in a rope as long as the other rules are followed? If this is permissible, what about the diameter of the loops? The rule limits the total diameter to 10 inches. Does this mean 5 inches per loop if there are 2 loops, or can each be 10 inches?
Answer
There is no rule that prohibits multiple loops in the same ROPE. I04-G applies to the ROPE as a whole, not additive of each component or modification of the ROPE, thus I04-G defines the maximum diameter of a loop.
and
https://frc-qa.firstinspires.org/qa/57
Question
Is a splice considered a knot for the purposes of altering the rope?
Answer
No, a splice is not a knot. Splicing is defined as "join or connect (a rope or ropes) by interweaving the strands." Thus, a spliced ROPE does consist of fibers woven together (per I04-D), but would need to satisfy the 1 in. maximum width specified in I04-A
Do you interpret this to allow multiple loops at the end of the rope (see attached sketch)? I would love a larget target to hit (yes I realize spooling up these extra loops or a large knot could be a pain)
Thanks!
-matto-
Name:	Rope Question.jpg
Unread 16-01-2017, 15:31
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Rope - Multiple Loops
I don't think multiple loops of the SAME rope, no splicing, would be an issue. As long as you do not violate:
G. if knotted or looped, the total diameter does not exceed 10 in. (~25 cm) (D)
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
