I.R. in love with you!
Unread 16-01-2017, 14:04
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Robust way to rotate an 18 inch square plate 90 degrees.
In general, what would be the most robust way to internally rotate a plate from horizontal to vertical (hinged on the bottom) that when in a vertical orientation is 18"(h) x 18"(w) x 3"(d).
We have researched cams, linkages, pulleys, acme screws, etc and are wondering what you think the most robust method of rotating a plate would be with very limited resources and no machining capabilities.
Thank you, so much for your time.
Unread 16-01-2017, 14:13
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Robust way to rotate an 18 inch square plate 90 degrees.
Have you looked in to air?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 16-01-2017, 14:32
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Pneumatics are good they just may take up to much space.
Otherwise I'd look into using either a window motor / 775 pro with a 100:1 ratio connected to a through shaft
and supported by bearings on either side
Unread 16-01-2017, 15:08
FRC #5523
Yes. air is good, but without a pneumatic specialist we are going to pass on that his year. Thanks for the motor/gear suggestion.
Is the trough shaft a long, screw drive?
What kind of bearing system would mount onto the plate?
(We are trying something new and really appreciate the help, thank you.)
Unread 16-01-2017, 15:39
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
One option would be to attach the plate to a shaft and then use a motor with a large reduction to rotate the shaft, rotating the plate. Another option is to put the plate on hinges and attach spring to the end so the plate is always being pulled one direction. Then attach a rope to the end of the plate and use a winch system to pull in the rope, pulling back the springs and rotating the plate. There are plenty of other options, those are the ones that came to me off the top of my head.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 16-01-2017, 15:47
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Numerous teams have pinned chain to the perimeter of a place and driven that chain with a sprocket/motor. Usually supported by a lazy susan of some sort.
Unread 16-01-2017, 15:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Yea, this setup is pretty cool. It's like 2 gears. With #35 chain the margin of error between the sprocket and the moving piece is huge.
2017 Scoring Model
CAD Library | GitHub
Unread 16-01-2017, 15:58
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Just my opinion, but you (personally) should become the pneumatic specialist. At a high level I feel that simple pneumatics are a lot easier than simple motors and shafts.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Crew Cox's Avatar
FRC #5546 (A.R.T)
Team Role: Driver
The first option is what I was referring to, and I'd use bearing blocks to support the shaft right after the motor and after it came off the other side of the plate.
Unread 16-01-2017, 16:05
D.Allred's Avatar
D.Allred D.Allred is online now
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Linkage driven by a window motor is a simple way to do this. Linkage is pinned to a disk that is rotating at the end of a shaft. This is the same linkage concept as translating rotational to linear movement. It is essentially two position.
David
Unread 16-01-2017, 16:07
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
And they are very addictive for a low resource team, more forgiving on the build, and easier to program, and less likely to self destruct when the programmers get a hold of it.
If you use a motor, when you raise it you want to hold it up... so motor runs into a stop, then what.... turn the motor off, does it fall, stall the motor into a hard stop, does the motor burn up... we have been a successful low resource team, we use a lot of pneumatics. We have more resources now.
The sooner we get behind schedule, the more time we have to catch up.
Unread 17-01-2017, 01:24
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
How much does this "plate" weigh? How much time are you willing for this process to take? These two numbers can tell you how much energy per move and power during the move you need. Once you know these, you can quickly eliminate actuators which are too small or way too big.
Also, it seems strange to call something 1/6 as thick as it is in the horizontal direction a plate; is it really that thick?
Unread 17-01-2017, 10:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I would definitely use pneumatics for something like this. It's mysterious, but once you make a little effort to understand it, it's simple, and makes moving hinged things really simple. Best part...no machining required! you can make hinges with a drill and a bolt.
But you do need to be aware of the limitations of pneumatics. They mostly only work for things that need to be in either of two positions, not stopping in the middle. And the motor that powers the compressor is not very large, which means that you cannot get a lot of work out of the system...so use it for relatively small low force things. Don't try to lift a robot with pneumatics! instead, use it to actuate things.
Unread 17-01-2017, 11:20
FRC #5523
Weight with its load ~ 3 lbs (I estimate the CG arc will be about 12 inches from center )
The measurements are the overall volume, the actual plate is more like an "L" shape probably made out of 1/8 to 1/4 inch thick material. (don't know yet, but I think the weight is correct either way).
Would like it to complete its 90 degree rotation in < 3 seconds (more like a slamming up action)
As an aside, who makes FRC compliant actuators, please? The one company I found last night https://www.servocity.com said his motor wasn't compliant.
Thank you.
Unread 17-01-2017, 11:26
FRC #5523
Yes, I am seeing the great advantage for learning pneumatics!
Thank you so much for the extra tips and considerations.
I have put this in my off-season planner for learning and experimenting with. Right now, time is not available, though, so I am seeking an end-run through some combination of cams, linkages and levers that I can make out of plywood or the aluminum tubing on hand.
