Go to Post Often when discussing GP, the P half gets forgotten. - Taylor [more]
Unread 16-01-2017, 17:35
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
Re: Talon SRX CAN Code
You can still use the open 2/4 Motor VIs - you just have to select the "Existing Motor" option and then wire the Device Reference from a Talon SRX Open VI (which can be found in the CAN Talon SRX palette after you've installed the Toolsuite).
There's an example of this in the Simple Arcade Drive Example in our GitHub.
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
