Go to Post And, by the way, we're all weird. It's just a matter of how well you hide or show it. :D - Billfred [more]
Unread 16-01-2017, 20:29
Robodragons4630 Robodragons4630 is offline
CHS Robodragons Programming
AKA: Noah Jarnigan
FRC #4630 (Robodragons)
Robodragons4630 is an unknown quantity at this point
C++ driver station enable issue
So I can build my code with no errors and deploy to the Rio no problem. On the driver station are three lights are green(communications, robot code, and joystick). However, whenever I click enable on the driver station it tells me there is no robot code. It disables and two seconds later the driver station says it has code. If i click enable the same thing happens again. Someone else on our team has deployed to the Rio and it doesn't give them this issue. I know my computer shouldn't have an issue with it because yesterday LabView code was deployed to the Rio and it had no problem. I have also deployed code from the same laptop to other Rios no problem.
