Go to Post I've never encountered a motor as forgiving as a CIM - Stall them for 20 seconds, run them hot on a short turnaround, or call them mean names in between matches and they'll just keep doing their thing. - thefro526 [more]
Unread 16-01-2017, 21:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Team 95 2017 Build Thread
Originally Posted by Lil' Lavery View Post
I'm playing the "figure out what that cylinder does" game right now, and I'm batting about 50%.
If I'm guess correctly, that's going to be a lot of air usage per cycle.
So the pair of overlapped cylinders from green to yellow are probably to tilt the yellow bit down to ease the gear entry from the loading station. The four long stroke, small bore cylinders (plus linear rods!) from red to (probably) green are either to get the gear mechanism over the bumper into the wall for loading a gear, or maybe for putting it in place? There's the sideways one under the gear to pivot the blue wings open/closed on those hinges, I'm assuming that one has a bushing instead of a pin in the end of the cylinder.
And then the four in the corners of the chassis which are probably brakes.
That's definitely a lot of air consumption, even if you're regulating down since most of those probably don't need 60psi.
