#9
Re: Connection Issues
If the wifi light was not on, then run the radio through the FRC Radio Config Utility again.
You can also try cycling the radio power. For whatever reason, it failed to startup wifi. If it starts correctly the wifi light should be red, before the PC connects, and yellow after it connects. Last edited by Mark McLeod : 16-01-2017 at 22:20. |
