Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 16-01-2017, 18:57
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
WCP MCC Robot 2017 powered by VEXpro!
Hi Teams,
We are thrilled to announce our 2017 MCC Robot powered by VEXpro!
Related information is available here: http://www.wcproducts.net/mcc2017
Notes/Disclaimers:
*We did not plumb the pneumatics, so you will see a black pneumatic line at the end of the video
*A few spots stick past the frame perimeter, teams will have to do some work to make it fit inside the frame perimeter.
Special thanks to Gary Chahal, Harvey Rico, Elias Avila, Rohi Zacharia, Andrew Lawrence & VEXpro!
R.C.
MadTown Robotics Team 1323
Unread 16-01-2017, 19:24
brian5115 brian5115 is offline
FRC #5115 (Knight Riders)
Rookie Year: 2015
brian5115 is an unknown quantity at this point
Re: WCP MCC Robot 2017 powered by VEXpro!
Not sure if I would call shifting gearboxes "minimum competitive"...
It's also a bit off-putting that it can't pick fuel up off the ground.
But the climber is cool; I didn't realize the tall volume was tall enough to do that.
My version of an MCC is just a gear mechanism (maybe even static if it's reliable), a good climber, and a standard chassis. Help your alliance get 12 gears, then play defense until it's time to climb.
Unread 16-01-2017, 19:27
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Considering shifting gearboxes are a COTS item, I would. Also the lack of ground intake is what makes this part of an MCC because it's easy to implement.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 16-01-2017, 19:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Keep in mind, they do have a vested interest in selling their products.
Unread 16-01-2017, 19:38
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Does it extend outside the volume constraints withe the gear mechanism?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 16-01-2017, 19:40
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I wonder why they chose to have a few inch gap between the frame perimeter and the climbing mechanism. If they eliminated that gap couldn't the hopper be bigger? I see the battery is in that space, but there's room between the gearboxes (thanks to the fact that they're flipped) that it looks like the battery could fit into.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 16-01-2017, 20:08
JohnFogarty's Avatar
AKA: @doctorfogarty
That's a unique climbing mechanism.
While I'm not standing next to the robot with a tape measure nor did I build it. I would bet that is a safe assumption. The frame is probably under sized enough to allow for that door to open and close legally.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 16-01-2017, 20:25
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Not having shifting gearboxes is, in itself, unlikely to prevent a team from being competitive.
Don't get me wrong, I like shifters as much as the next guy, but to say they're the minimum requirement to have a competitive drive train/robot is somewhat ridiculous.
Edit: Still some really cool work by the folks at WCP-- I've looked forward the past few years to seeing what you come up with for an MCC, and it's always interesting. Keep up the good work!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 16-01-2017, 22:18
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
>bumper says 1323
>has an elevator
seems about right.
Really neat stuff, I like how 2009 it looks with that hopper/dumper system.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 16-01-2017, 22:39
OMGRobots1's Avatar
OMGRobots1 OMGRobots1 is offline
AKA: Robby Shield
FRC #5026 (Iron Panthers)
OMGRobots1 is on a distinguished road
What was your motivation to not build a floor intake for fuel?
Unread 16-01-2017, 23:08
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I wasn't that involved last year, but where there any teams last year that used your MCC robot or at least certain subsystems?
Unread 17-01-2017, 03:42
R.C.'s Avatar
Yeah the mechanism was designed to go vertical to the plane of the bumper, in the video we just had manual control so it rotated a little farther. The guys tried cutting the panel shorter where it was mechanically impossible to break the plane and it works well too. No difference in performance.
We basically wanted to create a robot that was easy enough for anyone to build without any cnc machines or mill/lathe abilities and that would be a perfect third pick for any alliance at the championship level. We should probably change the name to MCC+ or something
We shared the view that the robot must:
1. Have a shifting transmission to play defense and zip around the field. Can use ball shifter, dog shifter etc... Single speed could work as well. There are a ton of cots option, just pick one and go!
2. Have a feeder load gear mechanism. We thought the floor mechanism was too difficult to pull off and added complexity. The current mechanism is manually driven with no feedback and is very very easy to build. It probably works better than our team's current ground loader!
3. Ability to hopper load and dump balls into low goal, this is probably lowest on our priority list but figured it would be fun to see how it worked out. Also teams could contribute by dumping balls in auto.
4. Ability to hang will be a must, especially as a 3rd pick at the championship level.. We wanted to see if there was a simple way of doing this and if it was possible to do it in a single pull/linear slide. Also who doesn't love elevators! Really wanted one since our 2017 robot won't have one......
Good Luck to all teams this season!
R.C.
Unread 17-01-2017, 06:36
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
If being fast, and needing to push are advantageous for a game, then shifting should be on the table. It is part of kit bot on steroids, and should be in the mix for an MCC most years. It can be a bit costly, but with so many COTS solutions, it is easy to integrate. If you are leaning towards an MCC due to budget, shifters are not where I would spend my first $500, but they would likely be in the mix for the next $500 to $800 of budget.
A gear runner that can play defense would have been my MCC with the team trying to figure out a simple climb, which I think you guys nailed. I am really impressed how cleanly you found a climb that uses the field provided style ropes.
There are several other simple concepts a team can go after. Unfortunately this year, most simple concepts have a 50/50 shot of being useful to a high performing alliance. Some alliance may want some gears to be run, others might want a large storage volume or floor cleanup. Climbing is universally useful, so worth having in the mix for an MCC, especially if you can make it reliable.
As a reminder to folks, trying to do everything tends to lead to attempting a lot of things poorly.
Competitively speaking, it is better to be good at a couple things, the mediocre or poor at a lot of things typically.
Unread 17-01-2017, 07:56
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Did I read that right? Currentlimit was used for one of the mechanisms? That's a new talon SRX feature for this season so that's cool to see.
Unread 17-01-2017, 11:46
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
For the climber, isn't there a lot of force on that cylinder rod? Does it bend under the load over time?
