Go to Post Maybe FIRST made these bumper rules so IRI would have something to blow off come July. - Koko Ed [more]
Unread 17-01-2017, 11:33
Stayskull Stayskull is offline
FRC #0948 (NRG (Newport Robotics Group))
Stayskull is an unknown quantity at this point
Rules Question
If a ball goes out of play(off the field) then somehow makes it back on the field by itself, can you still score it as normal?
Unread 17-01-2017, 11:39
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Rules Question
yes
Unread 17-01-2017, 11:43
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the rough
Re: Rules Question
Yes you can. Check section 4.6 of the manual.
Unread 17-01-2017, 11:46
ARampantBrian ARampantBrian is offline
AKA: Brian Wyatt
ARampantBrian is on a distinguished road
Re: Rules Question
Any GAME PIECES that leave the FIELD will not be returned to MATCH play.
GAME PIECES that inadvertently bounce back in to the FIELD will be considered fair game.
Note that ROBOTS may not deliberately cause GAME PIECES to leave the FIELD.
Yes, so long as a robot does not intentionally cause the ball to do this.
Team 829 : The Digital Goats, Captain/Driver (2013-15)
Area 5188: Classified Robotics, Mentor/Coach (2015-17)
Team 829: The Digital Goats, Mentor (2017-????)
Mechanical Engineering | Class of 2019
"The difference between a successful person and others is not a lack of strength,
not a lack of knowledge, but rather a lack in will." —Vince Lombardi
Unread 17-01-2017, 11:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Rules Question
'Cause let's face it, we can't have the referees trying to track those two balls that bounced back in among the other five hundred that are the same size and color -- especially after they cycle through the robot and boiler.
Unread 17-01-2017, 13:07
petercooperjr's Avatar
petercooperjr petercooperjr is offline
AKA: Peter Cooper Jr.
petercooperjr is an unknown quantity at this point
Re: Rules Question
The even more interesting case is that per Q55, errant shots that end up in the loading lane or alliance station do need to be tracked down by field staff and removed. That was not the response I would have expected, especially given what I took to be the general intent of the general 4.6 Match Logistics "you own whatever happens to be there, even accidentally" rule for alliance stations and loading lanes to make it easy on field staff to enforce.
