Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 16-01-2017, 17:28
TheLegend27 TheLegend27 is offline
FRC #3260
TheLegend27 is an unknown quantity at this point
Post Strange Build.xml error?
Every time I attempt to run my program, I get a strange error that states:
BUILD FAILED
C:\Users\samjt\wpilib\java\current\ant\build.xml:1 67: The following error occurred while executing this line:
C:\Users\samjt\wpilib\java\current\ant\build.xml:3 39: server indicated an error: scp: /usr/local/frc/bin/netconsole-host: Text file busy
What is weird that there is not really anything on those lines. I have no idea what to do. It seems that the RoboRIO has a file open and it can't be accessed, so how do I "close the file"
Unread 16-01-2017, 17:40
RonanK687 RonanK687 is offline
FRC #0687
RonanK687 is an unknown quantity at this point
Re: Strange Build.xml error?
I also received the same error when attempting to upload code to the RoboRIO.
I've also tried downloading Apple Bonjour by Installing iTunes and I already had the NI mDNS Responder that came with the NI FRC Update Suite. I've also disabled my firewalls.
"https://wpilib.screenstepslive.com/s/4485/m/13503/l/242608-roborio-networking"
I still have no luck.
Unread 16-01-2017, 19:29
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Were you able to successfully deploy code before or is this your first attempt to deploy code? If you restart the roboRIO do you still get the same error?
I think its safe to assume the problem is not with your computer. Can you upload the full build log?
Unread 17-01-2017, 12:12
ABerg ABerg is offline
AKA: Amie Berg
FRC #6547 (Flaming Metal Robotics)
Rookie Year: 2017
ABerg is an unknown quantity at this point
I had the same problem. In my situation, I had run the code and then received the error message that req'd me to change the build path. I changed the build path (this is when you had to point to the jdk instead of the jre). When I ran the code again, I received the same error that you did. I then closed the driver station and disconnected from my radio. I then reopened the driver station and reconnected to the radio and ran it again and it ran fine. Not sure why that worked, though. Note that I did not close Eclipse during the process. Hope this helps.
Unread 17-01-2017, 12:51
FRC #3260
Problem is I have restarted the roborio and my computer and I still get an error. However, I tried the code with the exact same build file on another computer and it worked fine
Strange
Unread 17-01-2017, 18:02
FRC #3260
Also it should be noted that the file causing the issue is called network-host.
I was able to find this file in the same directory as the build.xml file in wpilib folder.
Unread 17-01-2017, 18:15
Psychicowl's Avatar
Psychicowl Psychicowl is offline
FRC #3039
Psychicowl is an unknown quantity at this point
I had a sort of similar problem I had forgot to install the Java JRE on to the RoboRio.
Unread 17-01-2017, 18:21
FRC #3260
I fixed the error. To anyone who needs this information, delete the files called network-host in
C:\Users\(your user)\wpilib\java\current\ant
There should be 2 files. A properties and a blank file. Just delete them.
