Go to Post Any mentor worthy of a WFFA would be delighted to see one of their fellow mentors receive the award. - dtengineering [more]
Unread 17-01-2017, 15:50
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: ball "fuel" hopper sorter
Originally Posted by Chris is me View Post
I really think the best way to do this is to not have to sort your hopper into a single feed. In 2009, the last volume scoring game, lots of teams trapped themselves into this paradigm early on and found their scoring potential harshly limited.
Do you mind providing an example or two of teams that did NOT have to sort their hopper into a single feed and were successful? I'm just not quite sure if I understand your point entirely.
Unread 17-01-2017, 16:03
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Talking Re: ball "fuel" hopper sorter
We are using the same concept as a paintball power hopper. Using a small motor with a rotor mechanism to keep pushing the balls around. It works great in my paintball hopper, we'll see if it works for this project. We're prototyping this with a small motor turning a lightweight rotor (3D Printed). Who knows. I really am hoping my team doesn't go obsessive/compulsive about this part of the game. I'd much rather spend time placing gears and hanging than wasting a load of time working on a shooter that shoots a ton load of balls for mediocre scores. Thank goodness the chassis, electricals, and gear delivery system is finished.
Unread 17-01-2017, 16:06
Joining the 900 Meme Team
FRC #0079
67, 971, and 111 are solid examples to start with.
Unread 17-01-2017, 16:11
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
unfortunately there is little match video, but our (1318) design in 2009 was 2.5 (ish) balls wide from intake to outflow. We won a regional and seeded #2 on Galileo.
I think his point was that once you commit to a singe stream shooter, you commit to a bottleneck mechanism, and if you skip the single width shooter, you may never need a bottleneck.
Unread 17-01-2017, 16:12
Chris is me's Avatar
AKA: Pinecone
Part of the challenge is that most of these robots converted themselves into short-range dumpers before too long, since it was very easy for this style of robot to do that.
67 was a two ball wide shooter, but balls that came up in the middle shot just fine.
228 was not the greatest robot, but I'm very familiar with that example - a 3 inch diameter drum across the entire width shooter with a lexan hood allowed for those kind of shots.
Dumpers that had more of an active "shot" out rather than a slower puke could be argued to be this kind of shooter - 47's rebuild, 254 / 968, etc. come to mind.
100's shooter is pretty much perfect for this, but their hopper did divide into two single file channels (I'm not sure that was necessary, but that's how it was).
The key design details tend to be the use of a roller of uniform diameter rather than spaced wheels, and the use of a curved backboard made from a single piece of plastic rather than separate "rails" used on some hooded shooters.
Unread 17-01-2017, 18:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I don't have any useful answer or suggestion here, other than I've just decided my personal term for this robot system is now "fuel injector".
Unread 17-01-2017, 18:26
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Compare the relative size of the goal and the game pieces in 2009 and 2017. It's much closer than you think!
Absolutely this!
Unread 17-01-2017, 19:24
Lord Basket's Avatar
Lord Basket Lord Basket is offline
President & Drive team coach
AKA: Parker
FRC #1719 (The Umbrella Corporation)
Lord Basket has a spectacular aura aboutLord Basket has a spectacular aura aboutLord Basket has a spectacular aura about
Impellers like those used in paintball guns are absolutely a good idea to prototype, but don't come in with the assumption that because it's the most effective loader for paintball, it must also be the most effective loader for robots this year. A big difference between paintball hoppers and robots this year is the size of the balls relative to the container.
Unread 17-01-2017, 20:04
PayneTrain's Avatar
PayneTrain PayneTrain is online now
please put down the gun
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
If I recall correctly, the shift from shooters to a different archetype was known as vomit mode in some places of the internet. Just wanted to give newer people a different search term.
On second thought, use that term very wisely...
Unread 21-01-2017, 15:52
tiernan12992's Avatar
tiernan12992 tiernan12992 is offline
LabVIEW Coding Captain and Weirdo
AKA: Tiernan Pierce
FRC #4490 (TechRaiders)
Rookie Year: 2015
tiernan12992 is an unknown quantity at this point
Our team has a relatively flat base on the bottom, but it is lifted at such an angle that the balls naturally roll into position for our shooter to collect them and fire them. Angles can be your best friend sometimes. And so can simplicity.
Nothing makes an engineer more productive than the "Last Minute"
"I will only work for 50 rubles." - Quenten, one of our other coders (extraordinaire)
"I guess I'm the help deadline. Please call NEVER." - Codi, our other coder. (It is funneh joke because Codi iz coder)
Unread 21-01-2017, 16:11
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Be careful about relying on gravity. Gravity-fed hoppers tend to jam and there's nothing you can do about it.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
