Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 17-01-2017, 16:29
WalnutsAndBolts WalnutsAndBolts is offline
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Re: Running Robot
Originally Posted by engunneer View Post
are you programming with labview, java or C++? which instructions are you using as a guide (link please so we can help you more quickly)
We are using LabView and here is a link:
http://wpilib.screenstepslive.com/s/...ogram-wireless
Unread 17-01-2017, 16:35
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Running Robot
your team number and battery voltage show up?
Are the communication, robot code and joystick lights all green?
those will say where to start.
also, other people that might read this thread, please jump in because i won't be available anymore pretty soon.
Unread 17-01-2017, 16:39
Rookie Year: 2017
Re: Running Robot
The communications and robot code are not coming up green.The team number is up, but I think that I manually entered it? I also did bridge my radio.
Unread 17-01-2017, 16:47
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Re: Running Robot
ok, focus on communications first. can you get to the roborio configuration page in a web browser (even if you don't have silverlight, you should at least get something)
verify your ip addresses or mDNS setup. http://wpilib.screenstepslive.com/s/...rio-networking
specifically the troubleshooting link http://wpilib.screenstepslive.com/s/...anual-id=24193
Unread 17-01-2017, 16:50
Re: Running Robot
Your radio should be setup as a 2.4GHz access point, not as a bridge, but if your selection had 2.4GHz in it anywhere, then it's okay.
Does your team number show up in your PC's wireless selection list and did you connect to it (example attached)?
Unread 18-01-2017, 10:15
Rookie Year: 2017
Re: Running Robot
I have that connected, but I can't drive the bot. I have attached an image of the driver station. The image is of our computer connected to the roboRIO via Ethernet dongle. I uploaded the basic code, but the robot is not responding.
Unread 18-01-2017, 10:16
Rookie Year: 2017
Re: Running Robot
Here is the link:
https://photos.google.com/search/_tr...0_QYCN8MhSqEnh
Unread 18-01-2017, 10:18
Rookie Year: 2017
Re: Running Robot
Here is the image
Unread 18-01-2017, 10:19
Rookie Year: 2017
Re: Running Robot
Actual Link here:
https://goo.gl/photos/8RejK5yHUt5hNfBM9
