Go to Post I miss the years when game speculation was based on an actual hint released in the form of unintelligible strings of numbers - tcallan [more]
Unread 24-01-2002, 23:44
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Cut a PWM cable in two pieces, then use the female end to plug to the torque motor. I believe you plug it into pins 1, 2 and 3, using two of them as positive and negative. There is a drawing of the polarity right above those pins, follow it.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
speeding up the torque motor archiver 2001 2 24-06-2002 00:13
How fast is the torque motor? archiver 2001 3 23-06-2002 22:55
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
