Our gears mesh perfectly!
Unread 16-01-2017, 14:40
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
high speed tracking
hi CD!
we are thinking about the idea of a flywheel for our robot, spinning at about 2000-3000 RPM (not entirely sure about this number) and we want to see how fast he is spinning, and we tried to use this encoder:
http://www.andymark.com/MA3-A10-250-...-p/am-2899.htm
this encoder couldn't measure the speed of the wheel fast enough...
how can we measure the speed of our wheel to know how fast he is spinning?
thanks guys
Unread 16-01-2017, 15:04
Re: high speed tracking
Originally Posted by ttnn58 View Post
That's an absolute position encoder:
Product Overview:
This kit contains one encoder and one encoder cable. The MA3 is a miniature rotary absolute shaft encoder that reports the shaft position
Select an encoder that's designed to measure speed.
Unread 16-01-2017, 15:15
Also, it has a sleeve bushing and the rated max speed is 100 rpm.
The datasheet is available via a link at the AndyMark page you posted. Download it and take a look. You may not understand all of it, but take a look anyway. It's a great way to start learning.
Name:	N = sleeve bushing.png
ID:	21556  Click image for larger version
Unread 16-01-2017, 22:45
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
MetaEngineer is an unknown quantity at this point
The best solution is an encoder meant to handle higher speeds, such as the Grayhill 63R series. It can handle up to 5000 RPM and we have found them to be reliable.
There are different resolutions available, so be aware which part number you are buying. Lower resolutions such as 63R32 and 63R64 will work for high speed flywheels such as yours. The high resolution 63R256 is better suited to drivetrain and other places where speeds are lower but you want more precise measurement at those lower speeds.
For checking the RPM of parts you have not put an encoder on, a laser tachometer is a very useful tool to have.
Unread 17-01-2017, 17:44
MACH MACH is offline
MACH is an unknown quantity at this point
Try the MACH Engineering Touchless Encoder: https://www.chiefdelphi.com/forums/s...d.php?t=153808
It was specifically designed for applications like this. You don't need extremely high resolution, there are no bearings to worry about, and mounting is a breeze!
Unread 18-01-2017, 08:45
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
I can also recommend the CTRE magnetic encoder:
http://www.ctr-electronics.com/senso...c-encoder.html
As well as the CUI AMP 10 series of encoders:
http://www.cui.com/catalog/component...mental/modular
We have successfully speed-controlled high speed wheels with both of these encoders directly connected to a Talon SRX.
Both encoders are available from AndyMark.
Unread 18-01-2017, 13:53
BDRessler's Avatar
BDRessler BDRessler is offline
Programming Lead
FRC #1828 (BoxerBots)
BDRessler has a spectacular aura aboutBDRessler has a spectacular aura about
We use the CUI AMT-103 encoders, they are super nice because they are robust and have an adjustable resolution.
Unread 18-01-2017, 14:51
Gdeaver Gdeaver is online now
FRC #1640
I'll 2nd the CUI AMT102 or 103. We have used them for the last 3 years and they have been rock solid. We got the AMT102 on the shooter Sunday hooked into a Talon SRX at 512 resolution. Testing done at 4100 to 4300 rpm. Using FPID looks very good but the graphs show that we need a fly wheel. CRE has done a good job. Proud of the programmers. They studied the CRE manual and got it up and running in a couple hours. This is not easy but with CUI and CRE we are getting there.
Unread 18-01-2017, 15:13
dtengineering's Avatar
AKA: Jason Brett
A more basic approach might be to use a reflective object sensor, such as a QRD1114 (or OPB706A, or any of a wide range of IR reflective sensors) and a bit of reflective tape on your wheel. If your wheel is already reflective, then use non-reflective tape... anything so you have part of the wheel reflective (shiny, white) and part of it non-reflective (dull, black). The non-reflective part could also consist of a hole in the wheel... anything that doesn't reflect IR light back into the sensor. You have to add a couple resistors to the QRD1114, but you'll find plenty of tutorials on how to do it.
This way you'll get one pulse per revolution... just use the RoboRio to time the interval between pulses and you're set. You can achieve the same thing by looking at the shaft... paint half of the shaft flat black, and leave the other half shiny.
Do note that the effective range of the QRD1114 is about 1mm. And that it has 1114 in it's name. If it's 1114, that means it's got to be good, right? :-)
Jason
Unread 18-01-2017, 16:44
Just highlighting this for emphasis. For a one-per-rev sensor, do not count pulses and divide by time.
Unread Yesterday, 00:25
Bendito's Avatar
Bendito Bendito is offline
AKA: Benjamin LaRoche
FTC #7837 (The Thunder Colts)
Bendito is an unknown quantity at this point
Just for future thread browsers, if that is the wrong way to do it, is this the correct way to count a one rev sensor as you suggest (obviously with some of the values changed)? It is similar to how we currently do it, and it seems to work well for high speeds. (Team476 example):
Unread Yesterday, 10:01
Originally Posted by Bendito View Post
Just for future thread browsers, if that is the wrong way to do it, is this the correct way to count a one rev sensor as you suggest (obviously with some of the values changed)?... (Team476 example):
I do not have a LabVIEW installation, so you'll need to answer some questions before I can answer yours.
Please post a screenshot of LabVIEW's help file for CounterGet.
I just checked Team 358's excellent LabVIEW examples web pages, and it looks like CounterGet returns the period (seconds/count). So yes, that appears to be using the FPGA to measure the elapsed time between counts.
How exactly do you do it? And are you using a one-per-rev counter? And how high is "high speed".
Unread Yesterday, 10:25
That's actually an old 358 example from 2010.
You don't need the Counter Start anymore.
Here's the Counter Get Help.
The period is the average of 5 samples in this example.
Unread Yesterday, 10:37
Thanks Mark. Where does it say 5 samples in that snippet? And how would you change that so it returns just the most recent period (which would be appropriate for a one-per-rev sensor)?
*I added the link in Mark's original quote above.
Unread Yesterday, 10:48
The "5" feeding into the Counter Config Timer is the number of samples to average over, so just make that "1".
In the original use of that example the 5 was meant to represent if you stuck 5 pieces of reflective tape onto your spinning wheel, so 5 samples represented a full revolution.
The example then drifted a bit over the years.
