Go to Post It's cool to see that Shaun White is an active team member (6th person from top left). That guy must be amazing, as he can win a gold medal in snowboarding while also being active on a FIRST Robotics team. - Andy Baker [more]
Unread 17-01-2017, 19:16
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
Post Axis Camera Not Displaying On Smart Dashboard
My team has been trying to get an Axis Camera (M1011) working for about a week now, with little success.
The Axis Camera light blinks green (we configured it to do that when it was being accessed), but the SmartDashboard "CameraServer Stream Viewer" displays red with "NO CONNECTION" text in the top left, for both the "Rectangle" and "Axis Camera" drop-downs that appear in the properties window.
We are running this code, with the camera static addressed at 10.3.3.31.
	public void enableRawCam() {
		rawThread = new Thread(() -> {
			rawCamera = CameraServer.getInstance().addAxisCamera("10.3.3.31");
			rawCamera.setResolution(160, 120);
			rawCvSink = CameraServer.getInstance().getVideo();
			rawOutputStream = CameraServer.getInstance().putVideo("Rectangle", 160, 120);
			rawMat = new Mat();
			while(!Thread.interrupted()) {
				String sdOutput = runRawCam();
				SmartDashboard.putString("vision thread output", sdOutput);
		rawThread.setDaemon(true);
		rawThread.start();
	public String runRawCam() {
		if(rawCvSink.grabFrame(rawMat)==0) {
			rawOutputStream.notifyError(rawCvSink.getError());
			return "errored";
		} else {
			rawOutputStream.putFrame(rawMat);
			return "did not error";
enableRawCam() is run in the constructor of another class, which is initialized in robotInit().
No errors display in the driverstation, but when we FTP into the Rio and get the log, we get errors as follows:
Exception in thread "CSListener" VideoException [edu.wpi.cscore.VideoException: wrong property type]
	at edu.wpi.cscore.CameraServerJNI.getEnumPropertyChoices(Native Method)
	at edu.wpi.first.wpilibj.CameraServer.lambda$new$0(CameraServer.java:432)
	at edu.wpi.first.wpilibj.CameraServer$$Lambda$2/5854261.accept(Unknown Source)
Exception in thread "CSListener" VideoException [edu.wpi.cscore.VideoException: invalid property]
	at edu.wpi.cscore.CameraServerJNI.getPropertyMin(Native Method)
	at edu.wpi.first.wpilibj.CameraServer.putSourcePropertyValue(CameraServer.java:313)
	at edu.wpi.first.wpilibj.CameraServer.lambda$new$0(CameraServer.java:418)
Default IterativeRobot.disabledInit() method... Overload me!
Default IterativeRobot.robotPeriodic() method... Overload me!
NT: server: client CONNECTED: 10.3.3.95 port 59487
NT: server: client CONNECTED: 10.3.3.30 port 62920
EDIT: We can access the camera through the web dashboard, so we know its probably not a problem with the camera.
Any help would be greatly appreciated.
The opinions expressed in this post are mine and do not necessarily reflect those of my team.
Unread 17-01-2017, 20:01
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Axis Camera Not Displaying On Smart Dashboard
Take a look at this ScreenSteps page for more information about this bug:
http://wpilib.screenstepslive.com/s/...-faqs-for-2017
Unread 17-01-2017, 20:18
AKA: Bradley Boxer
Rookie Year: 2015
When we restart all of the network table clients, the driver station floods with errors saying:
ERROR: connect() to 10.3.3.31 port 80 error 101 - Network is unreachable (TCPConnector.cpp:175)
But the camera still does not connect.
Unread 17-01-2017, 20:22
AKA: אוסטין
Can you still access the camera through the web dashboard?
Unread 17-01-2017, 20:24
AKA: Bradley Boxer
Rookie Year: 2015
Yes, the web dashboard still works fine.
Unread 17-01-2017, 20:31
AKA: אוסטין
I would restart your entire robot (roboRIO, radio, and camera).
Unread 17-01-2017, 20:57
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
We have restarted multiple times. This problem has persisted for the past 4 days.
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 17-01-2017, 21:03
AKA: אוסטין
If you open OutlineViewer (Eclipse Menubar -> WPILib -> Run Outline Viewer) What do you see listed under /CameraPublisher/{Camera name}/streams?
Unread 17-01-2017, 21:05
AKA: Bradley Boxer
Rookie Year: 2015
I just got back from our workshop, so I don't have access to the robot at the moment, but I will check tomorrow.
Unread 17-01-2017, 21:09
AKA: אוסטין
Tomorrow please also try running this code in a new project and test if the camera connects.
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.IterativeRobot;
public class Robot extends IterativeRobot {
    public void robotInit() {
Unread 18-01-2017, 17:25
AKA: אוסטין
After a private message discussion, we discovered another antivirus program was running and preventing SmartDashboard from connecting to the camera.
Unread 19-01-2017, 21:21
AKA: Bradley Boxer
Rookie Year: 2015
The camera stopped working again today, working fine over USB but repeatedly connecting/disconnecting several times a second when connecting via wireless. We were able to resolve the problem, and I would like to share the solution in case anyone else is encountering this issue.
In the NetworkTables outline viewer, our Axis camera had a value "streams" which contained a string array with
1) the wireless URL of the camera (10.3.3.2:something)
2) the USB URL of the camera (172.22.11.2:something)
The solution was to delete the USB URL. I believe what was happening was that the camera would connect over wireless, see that it had another element in the array that took priority and try and connect to it, fail on the connection, and re-connect over wireless.
Unread 20-01-2017, 04:50
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
SmartDashboard doesn't apply a priority, it just round-robins over each address if it gets disconnected. I would suspect it's still getting disconnected from the wireless URL, you're just not seeing the disconnects because it reconnects successfully with minimal delay. Can you run SmartDashboard from a command prompt so you can see what's being printed to the console (the executable is located in C:\Users\yourname\wpilib\tools)? In particular, I'm interested in seeing the "Trying to connect to:" and "Connected to:" messages. Can you also state what the URLs actually are?
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
