Go to Post Developing new "classes" of super-competition would totally defeat the concepts of info-sharing, partnerships, alliances, etc and create an elitist society within FIRST. - dhitchco [more]
Unread 17-01-2017, 21:33
iterevo iterevo is offline
FRC #0967 (Iron Lions)
Rookie Year: 2016
iterevo is an unknown quantity at this point
java.lang.NullPointerException
We have been trying to figure out the new CAN Talon libraries given to us this season. After looking through numerous examples, we cannot get around this error:
ERROR  1  ERROR Unhandled exception: java.lang.NullPointerException at [org.usfirst.frc.team967.robot.subsystems.DriveSubsystem.arcadeDrive(DriveSubsystem.java:27), org.usfirst.frc.team967.robot.commands.TeleOp_ArcadeDrive.execute(TeleOp_ArcadeDrive.java:23), edu.wpi.first.wpilibj.command.Command.run(Command.java:243), edu.wpi.first.wpilibj.command.Scheduler.run(Scheduler.java:206), org.usfirst.frc.team967.robot.Robot.teleopPeriodic(Robot.java:109), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:130), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)]  edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:249)
 Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:249): ERROR Unhandled exception: java.lang.NullPointerException at [org.usfirst.frc.team967.robot.subsystems.DriveSubsystem.arcadeDrive(DriveSubsystem.java:27), org.usfirst.frc.team967.robot.commands.TeleOp_ArcadeDrive.execute(TeleOp_ArcadeDrive.java:23), edu.wpi.first.wpilibj.command.Command.run(Command.java:243), edu.wpi.first.wpilibj.command.Scheduler.run(Scheduler.java:206), org.usfirst.frc.team967.robot.Robot.teleopPeriodic(Robot.java:109), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:130), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)]
 WARNING: Robots don't quit!
 ---> The startCompetition() method (or methods called by it) should have handled the exception above.
 ➔ Launching «'/usr/local/frc/JRE/bin/java' '-Djava.library.path=/usr/local/frc/lib/' '-jar' '/home/lvuser/FRCUserProgram.jar'»
 ********** Robot program starting **********
 NT: server: client CONNECTED: 10.9.67.144 port 56534
 Default IterativeRobot.robotPeriodic() method... Overload me!
Here is the link to our github to view all our code: https://github.com/FRC-IronLions-967/2017SteamWorks
The robot code will build and deploy correctly, and shows no errors. However when you enable the robot, the robot code drops out after a couple seconds and the above error appears.
Thanks,
Any help is appreciated
Team 967
Unread 17-01-2017, 21:48
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
Re: java.lang.NullPointerException
Looks like you are instantiating your CANTalons in RobotMap.init, but I don't see any calls to that method. You probably want to call that from your Robot class on startup.
I'm don't think RobotMap is really the right place for the CANTalons, but that's a whole different issue unrelated to the error.
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Line 27, as of commit d16c532, cannot possibly throw a NullPointerException:
if((xAxis< deadBand) && (xAxis > -deadBand)){ xAxis=0;}
Are you sure the code on the robot is the same as the code on Github?
Edit: Ben's right. You declare the speed controllers in RobotMap, but never call init() so they're always going to be null.
WPILib
GRIP, RobotBuilder
Unread 17-01-2017, 22:02
Rookie Year: 2016
We are very sorry about the code not being up to date on the github, we were messing with the code to get rid of the error. We have updated that now.
As far as the CAN Talons being instantiated in Robot Map, we are calling them in the DriveSubsystem.java file
Thanks for the quick responses, hope that helps
Unread 17-01-2017, 22:14
FRC #2084
The issue is that when your subsystems are initialized, they get their values for all the RobotMap variables before those variables have been initialized. So you can either
  1. Initialize subsystems after calling RobotMap.init(); or
  2. Call RobotMap.init() in a static block in the RobotMap class; or
  3. Remove RobotMap.init() altogether and initialize its contents inline
What you're basically doing is:
Object a = null;
Object b = a; // set b to the _current_ value of a, which is null
a = new Object();
b.doSomething(); // null pointer exception!
WPILib
GRIP, RobotBuilder
Unread 19-01-2017, 20:18
Rookie Year: 2016
Smile Re: java.lang.NullPointerException
Thank you very much. We were able to figure out our issue. We appreciate the help and the quick responses.
Team 967
