Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 17-01-2017, 23:03
mid air collision
Here's a fun little spreadsheet.
Put your launch speed, launch angle, and firing rate into cells L2, L3, and L4.
Column D will show the gap, in inches, between the balls.
If the gap is negative, the cell will be red.
This model just uses parabola equations for simplicity. Air drag is ignored.
You can easily select a relevant portion of columns B and C and graph it to see the balls appropriately spaced in mid-flight.
Unread 17-01-2017, 23:31
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
Re: mid air collision
Interesting tool, very useful for determining potential issues with current prototypes.
I turned it into a Google Sheet and added a y_0. I guess it would be fairly easy to expand this to have drag factored in which probably has a significant impact on midair collisions.
Link to Sheet
Just click "Save as Copy" to edit it yourself.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 17-01-2017, 23:52
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Whoa whoa whoa.
"Air drag is ignored." - Ether (2017)
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 19-01-2017, 18:32
Here's a fun little spreadsheet...
... and here's a fun little gnuplot script that plots 5 inch diameter circles with spacing corresponding to the launch speed and firing rate.
1) download and install gnuplot
2) run the script !
File Type: txt ball_gap.txt (427 Bytes, 20 views)
Unread 19-01-2017, 19:09
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by SenorZ View Post
Whoa whoa whoa.
"All models are wrong but some are useful."
-George Box
If there isn't enough spacing without air drag, there certainly won't be enough spacing with air drag
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 19-01-2017, 21:00
-George Box
Indeed.
And some models are useful for engineering, while others are useful for teaching/learning.
the spreadsheet shows how to use parametric equations to get an XY plot with points a constant delta time apart.
Unread 29-01-2017, 11:00
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Love this tool. Thanks Ether. I was playing around with it last night and this is pretty curious.
# User Parameters:
V = 35.0 # launch speed ft/sec
q = 82.0 # launch angle degrees
bps = 12 # balls per second
35 feet per second is approximately what a cim motor on a 4" wheel and efficiency losses included. If you can feed at 12 balls per second (ludicrous I know and keep the speed up on the motor (2 cims maybe for the torque and a flywheel?) They actually won't hit each other. Now that means the balls are going practically vertical, so the affect of the air on it's downward path will be interesting. It make not take a very good trajectory on the downward side. Once we are down with our production gear loading / unloading, and the climber, this is our third priority, so we'll know with testing.
But until then it makes me think will a flatter path or a more upward path work better?
Any thoughts? Ether? Richard?
Unread 29-01-2017, 11:40
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
# User Parameters:
What goes up must come down. In this example, the FUELs will peak ~12 ft. above the 21" diameter HEG. As you observed, they might not all come down by the desired path.
Richard Wallace
since 2003
Unread 29-01-2017, 11:41
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Our testing, so far, confirms and alingns accuratly with this tool. Longer, flatter shots do indeed have less tendency to interact with each other.
That said, there is a variable that is difficult to compensate for, the fuel have holes. Getting consistent, repeatable contact with the same part of the fuel is next to impossible to do at a rate that is reasonable to be competitive.
The fuel fly fairly straight when fired with backspin, but the apex of the parabolic path can be different from shot to shot because of the non repeatability of fuel contact. Thus the trade offs in choosing which shot to take come down to:
Can you aim reliably enough at a longer distance and repeat the distance of the shot enough to successfully make shots at a higher rate than shooting close and dealing with fuel collision will produce?
Unread 29-01-2017, 11:53
Attached is the gnuplot graph and script for 35 82 12.
As you can see, the balls are pretty close to each other at the top.
I agree, at that speed and angle (and length of flight path) air drag will be a factor.
This is mostly a teaching and visual-aid tool. You really need to prototype and test !
Name:	35 82 12.png
File Type: txt 35 82 12.txt (431 Bytes, 1 views)
Unread 29-01-2017, 12:00
billbo911's Avatar
... This is mostly a teaching and visual-aid tool. You really need to prototype and test !
^ Absolute truth! ^
Unread 29-01-2017, 12:09
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I would recommend tweaking the tool timing down to 0.125 seconds. I have found with realistic values, that the smaller time window gives a lot of insight.
Unread 29-01-2017, 12:20
Yes absolutely agreed on the testing. We did some with a wooden mock up to prove to ourselves we are in the ball park with a mini cim and weighted flywheel style shooter. Now we are finalizing our gear and climber (our priority), then I have two students working on the shooter hard design. We didn't use an encoder for speed yet, so we need to get that going and then we can get some usable data on the shot. The plotted data will give us something to go off of to start the testing and help set our ranges. Then we will see from there!
Thanks for the input everyone!
Unread 02-02-2017, 12:25
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Thoughts on what would be involved to accommodate for a 2,3,4,5? wide shooter? Assuming the balls do not significantly interact between 'layers' I suppose you could used a constant feed per 'layer' or a constant feed with a random component per 'layer' to simulate rapid evacuation of a hopper. So it would essentially be running one simulation per 'layer' and plotting them all at the same time.
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
